Old 09-16-2006, 06:47 PM   #1
Neuo is an unknown quantity at this point
Angry Plz. Help With QSTARZ GPS
im a new on gps world i have buy qstarz BT_880 gps and i cant find software that work with it and the offical site www.qstarz.com dont tell enough informaiton
Any Ideas ?? please help
Neuo is offline   Reply With Quote
Advertisement Sponsored links
Old 09-16-2006, 06:53 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Most GPS receivers for the PC don't require any software other than the GPS application (such as Streets & Trips, iGuidance, Destinator, etc.) to work properly.
For the unit you're looing at, you would need a bluetooth adapter for the PC you want to connect to the GPS receiver, obviously. The bluetooth adapter should be capable of using the bluetooth connection as a virtual serial port.
There are plenty of FAQs in the FAQ Emporium subforum that relate to GPS that will likely answer your questions.
Good luck.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-16-2006, 07:11 PM   #3
Talking thank you for the fast replay
i use navigon NCK 5 software the gps connect to the bluetooth on the computer using serial port number 11 and its work the blutooth light on the gps shows me that its connected but when i put the same serial port in NCK software the software cant detect the gps reciver ??
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
My GPS scenario & Bluetooth quest. gizak GPS 13 04-12-2005 01:11 PM
Delou Routis GPS USB install issues, please help... jedi7001 GPS 8 03-26-2005 11:29 AM
few gps questions fuctup GPS 2 03-02-2005 02:40 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
