Old 09-25-2006, 07:44 AM   #1
Hamzeh is an unknown quantity at this point
Exclamation Help me Started!
I want someone to tell me about the format of the data generated by the reciever so that i can use it to build a software on a microcontroller that read the data from GPS receiver.
All what i have seen only explain the technical things and also with no details on the steps of build the system from the first step to the last step.
Hamzeh is offline   Reply With Quote
Advertisement Sponsored links
Old 09-25-2006, 07:54 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Most off-the-shelf GPS receivers output NMEA data. (Some output data in other formats, like the Garmin proprietary format).
Here's a good informational link about the structure of NMEA sentences. It's not all that difficult to decode: http://www.gpsinformation.org/dale/nmea.htm
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Accidental short on car amp , started making a pulsating high bass noise PLEASE HELP! Paulek Car Audio 4 06-17-2006 12:00 PM
New carputer project started - 350z (56k beware) StutterinJ Fabrication 11 05-22-2005 08:45 AM
Started Carputer, having Opus problems? shuluke Power Supplies 7 01-20-2005 02:57 AM
Warning... crazies ahead. ddt Off Topic 57 05-12-2004 12:06 AM
Getting started Xanxes General Hardware Discussion 2 02-18-2003 12:39 AM
