09-27-2006, 03:59 AM
#1
NMEA Decoding?
I want to ask if some one have decode the NMEA standard signal generated by the GPS receiver, using microcontroller(preferable) or the serial port with his own software?
If someone do this thing, please send me the details and the steps to do this brililiant thing.
09-27-2006, 04:07 AM
#2
My Village Called
09-27-2006, 04:34 AM
#3
Yea, i have read about the NMEA, but still there are some questions.
One of them, 4800 baud per second, how much the baud is? and is the "no parity" bit sent or not?
09-27-2006, 04:50 AM
#4
09-27-2006, 04:51 AM
#5
My Village Called
Try it with hyperterminal first and see.
12-12-2006, 05:44 PM
#6
If still needed :I did some test with a PIC 18F455 and an LCD display.
12-12-2006, 05:50 PM
#7
Raw Wave
Take a look at the Perl Library, GPS::NMEA
03-12-2007, 04:26 AM
#8
LAssen Lp GPS NMEA data
Pls let me know , how to enable the NMEA data out in Lassen LP GPS module using Hyperterminal
03-12-2007, 05:05 AM
#9
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Create a new connection, specify the port, speed,settings = 4800, 8, N, 1 (or something like that.. )
Save it, Hit connect. You should start seeing the GPS/NEMA sentences flying by...
03-12-2007, 05:37 AM
#10
i couldnot see the NMEA messages but could see only some junk data of symbols..
Thanks for the reply....
I did the same as you mentioned, but i couldnot see the NMEA messages but could see only some junk data of symbols..
I even tried with the TSIPMonitor32.exe, but could not get the data in it. Please help me with steps, how to use TSIPMonitor.exe.I even gone through the Lassen LP Manual.
The manual is explained according to the starter kit. but I m not using Starter kit instead I interfaced Lassen LP module to PC serially through Max232.
waiting for the reply..
03-12-2007, 05:56 AM
#11
The View of the Hyperterminal DATA is attached
03-12-2007, 06:43 AM
#12
try adjusting your speed (baud). some receivers send out at 9600
03-13-2007, 12:21 AM
#13
3.3V Back up Battery is required for the GPS to give NMEA data?
I have tried for different baud rates, but the junk data remains same. At present i did not connected any backup Battery to the Lassen LP GPS module.Please confirm, whether the 3.3V Back up Battery is required for the GPS to give NMEA data.
03-13-2007, 02:12 AM
#14
Anyone help me in getting NMEA massages in Hyperterminal. I want to know whether Back up Battery is needed for getting NMEA data
03-13-2007, 03:01 AM
#15
FreeDrive Creator
have you confirmed your device works at all ? looks like its knackered to me
| Thread Tools |
| Display Modes |
Linear Mode
