I was having trouble with my bu353. It was working fine one day and then the next I was trying it, and no matter what I did I could not get it to work.
I searched around a bit and found out there's a battery inside the device, and I think it keeps some temporary memory for what port it's plugged into or something like that. When you start switching it from one port to the next it will stop working. The unit says to unplug for X amount of time for the device to reset itself, but I tried that and it still didn't work.
Since I was impatient and didn't feel like waiting till another day I opened it up and wanted to temoprarly remove the battery to see if it would work, but I accidently tore it right off, and it started working immediantly, and has been fine since. I think the only difference is it takes a little longer to get it's first lock, but then all is fine afterwords.
