Old 10-05-2006, 03:20 PM   #1
GPS_guy's Avatar
Question I have a big question about BU-353 (USB GPS receiver)
When I am using laptop with GPS, it doesn’t work very well. When I used integrated GPS in a car it worked just good, but laptop + GPS set, doesn’t work as smooth as car unit. The problem is, laptop + GPS set works very slow, it looks like there is time delay (~5 sec) between what is happening on the road and what I see on the screen.
After reading this thread, I’ve found that USB unit works worst then serial unit (BU-355), but does it really that bad?
http://www.mp3car.com/vbulletin/show...dead+reckoning
My question is: is my problem in USB? I have no other trouble except this “slow real-time” response.
Or maybe my laptop is too slow?
1st: Acer Celeron M 1.5 Ghz, 768Mb RAM, Intel graphics 128 MB, WinXP SP2 MS Streets and Trips 2006.
2nd: Dell P2 650 Mhz, 512 Mb RAM ATI Mobile 8 MB, Win2000 SP4 MS Streets and Trips 2006.
Two laptops with same problem.
Or is it buggy software: MS Streets and Trips 2006?
If some one is using similar configuration please post here, what you experience with this BU-353?
I am thinking that my receiver is defected and maybe I should exchange USB with Serial type, Help me please.
GPS_guy is offline   Reply With Quote
Advertisement Sponsored links
Old 10-05-2006, 03:40 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
There is nothing wrong with either the software or the laptop.
I have a BU353 GPS and have no problems with it.
Make certain teh COM port that the GPS uses is set to 4800 baud, 8 Data bits, 1 Stop bit, No parity.
Are you using the prolific serial-to-USB drivers? If not, hunt them down and find them, or install from teh CD that should have come w/ your BU353. They're easy to locate on the web.
The last possibility is a faulty or non-working unit. If you purchased new, it should be under warranty.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 10-05-2006, 06:56 PM   #3
GPS_guy's Avatar
Thanks for reply,
I followed instructions which were in manual.
Here is what i have:
COM4
Bits per second: 4800
Data Bits: 8
Parity: None
Stop bit: 1
Flow control: None
I used drivers from CD, and I tried drivers from their website,
same result.
Addition:
On website I found line which sad:
Chipset: SiRF Star III v3.1.1 firmware WAAS Enabled by default
But on my box it is written:
S/N *******
Ver: 3.2.2 09/06
WAAS Enabled default unit
Maybe this newer firmware (3.2.2) is worst then older (3.1.1) , maybe it doesn’t work very well. I am trying to say that my “bad” unit is different from your working unit.
Old 10-06-2006, 05:02 AM   #4
Marvin Hlavac's Avatar
The 3.1.1 is the firmware version (which I believe is the most current, but don't take my word for it). The 3.2.2 likely refers to the version number of the product.
Is it really ~5 sec delay you are seeing? One or two sec would be normal, but 5 wouldn't.
Marvin Hlavac is offline   Reply With Quote
Old 10-06-2006, 07:36 AM   #5
GPS_guy's Avatar
It is defiantly more then 1-2 second, when MS Streets and Trips 2006 tells me: “in 0.2 miles turn right”, and by the time I hear that I already missed the turn , my speed was about 35 mph.
I think I am going to return my GPS BU-353 and try BR-355 Serial GPS Receiver; maybe serial port will work better.
Question about USB powering of the GPS receiver. acura cl GPS 5 10-05-2006 04:45 PM
Holux GPS 213 USB Gmouse receiver virginblue Classified Archive 0 08-15-2006 12:15 AM
Best USB GPS Receiver? L-U-R-C-H GPS 14 06-20-2006 11:50 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 07:30 AM
Best USB GPS Receiver to get? Xtreme2k2 GPS 1 05-11-2004 08:26 PM
