Old 10-17-2006, 12:13 AM   #1
Creoden's Avatar
Help choosing GPS within 48h
I am in the market for a GPS Receiver; the problem is I need it within 48 hours, so it appears that I am stuck with buying one from a Brick and Mortar store such as Best Buy. I have looked at what they have available and made a small chart, It appears that the Pharos Igps-500 is the best because of the chipset, but it looks the most cumbersome as it has to have a USB dongle attached to it, and then the USB cable attached to that.
I would like one that just either has a USB cable coming off of it, or just a USB port on it. Along with one that would allow an external antenna, but for that most likely I am looking at some form of OEM one that would be needed.
Here is the info I was able to gather
Pharos iGPS-500 (Comes with Microsoft Streets & Trips 2007)
Price: $130
Specs: http://www.pharosgps.com/support/spec_igps500.htm
Chipset: SiRF StarIII GSC3f
Pharos iGPS-360 (Comes with Microsoft Streets & Trips 2006)
Price: $130
Specs: http://www.pharosgps.com/support/igps360_spec.htm
Chipset: SiRF StarIIe/LP
Earthmate LT-20 GPS:
Price: $100
Specs: http://shop.delorme.com/OA_HTML/DELi...minisite=10020
Chipset: SiGe RF chip SE4100L & ST Micro Vespucci STA2051
Garmin GPS-18
Price: $130
Specs: http://www.garmin.com/products/gps18/
Chipset: ??
Note: no NMEA Output
Any help would be greatly apreciated...
I have looked over other GPS threads, and keep getting too confused...
This posting is provided "AS IS" with no warranties, and confers no rights.
Creoden is offline   Reply With Quote
Old 10-17-2006, 12:44 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
The M$ S&T GPS work really well and the cable is detachable for easy routing. I got mine from Circuit City with instant rebates for about $60 with the software included. Works well. You can hide it in the dash, and all will be peachy.
2k1Toaster is online now   Reply With Quote
Old 10-19-2006, 12:14 PM   #3
buy the pharos 500, return it after you're done with it.
then buy BU-353
skuller is offline   Reply With Quote
Old 10-19-2006, 03:03 PM   #4
2k1Toaster's Avatar
then buy BU-353
the little pharos that comnes with S&T is wonderful. Always gets a lock from cold boot wihin about 5 seconds. It also has the availability to takie it off the usb cable, and plug it into a bluetooth transmitter, or a compactFlash/PCMCIA slot adaptor. So really 3 different formats. I live in Colorado and there are a quite a few mountains. I live on cheyenne mountain. With all the cloudy skies, feet of snow, 14000 foot mountains and interference from NORAD, it works like a charm. And why not for such a low price. Only downside I have had so far, not magnetic mount. Comes with a suction ciup. But to be able to stick it in a bletooth adaptor and use it on my phone or PDA or bring to anotehr car without hving t take out my propretary cable from routed in m ydash more than makes up for it.
Old 10-19-2006, 03:24 PM   #5
jeffreyd_tx's Avatar
The Garmin rocks for me. I get a sat lock by the time iguidance launched. It looks real nice mounted on the car too.
jeffreyd_tx is offline   Reply With Quote
Old 10-19-2006, 03:31 PM   #6
bu 353 lowest price I found, $66
well, i don't need all the bluetooth thingy.. $$ matter
Old 10-19-2006, 04:50 PM   #7
2k1Toaster's Avatar
pharos: http://cgi.ebay.com/MICROSOFT-STREET...QQcmdZViewItem
$30 + $7s/h
lower than $66. And it comes with the USB cord and Streets and Trips 2006 so you have software too. Also I'm not saying that it is bluetooth, it comes with usb cord and you can buy a bluietooth adaptor. Basically expandable.
Expandable for under $40, not expandable for over $65.... hmmmm
Old 10-18-2007, 12:56 AM   #8
If you buy it on Ebay used, can you still use it? I thought Microsoft doesn't allow you to buy software that is used or register to someone else, but I'm not sure if that's true or not. Can the license for S&T be transfered to the new owner? Does this Pharos hardware work with any other software? I searched downloads.com and wasn't able to find anything that works with this hardware.
lovingGPS is offline   Reply With Quote
Old 10-20-2007, 02:27 PM   #9
2k1Toaster's Avatar
S&T 2006 needs no activation. If you have the disk, then it is yours. I do not know about 2007. I dont have it.
Also the actual hardware is completely independant of the program. It is actually a pharos unit that microsoft is selling.
Old 10-20-2007, 03:27 PM   #10
anything in that list is better than the Earthmate LT-20. a broken compass would be better. I have one myself that I got from a friend. It @#$$ing sucks. That's being nice too. Doesn't take too terribly long to get a lock...when you CAN get a lock. If the sky is cloudy...good luck. If it's raining... you may as well unplug it and plug a gerbal into your usb port. It's not worth $100...it's not even worth the price of free that I got it for since it's caused so many headaches and time spent trying to get it to work. It's off by a number of yards at times, sometimes it just quits sending data to my pc, I have a 1 in 3 chance of it actually working when I power on the pc (not coming out of hibernate either), when it rains... that's when the real fun begins. Your elevation will be mis-reported...not a big deal really, but your location jumps around...sometimes you'll be a couple hundred feet ahead of yourself...and then the next second, you're a street or two back behind, and not to mention that it reports my speed in wacked out ranges... for example...I'll be going 30mph...yet it says 50-100mph. It's a real treat really...
As long as you're not looking for a reliable GPS receiver, the LT-20 is a great choice if it was cheaper. However, if you're looking for the opposite of what I've described, check out a bu-353 or another unit based off the SiRFIII chip.
nst6563 is offline   Reply With Quote
Old 10-20-2007, 07:04 PM   #11
Marvin Hlavac's Avatar
From your list I would also pick the GPS-500. By the way, rather than buying S&T 06 or S&T 07, why not look around for S&T 08? The new version has been out for a while, and it must be in several of your local stores by now.
Marvin Hlavac is offline   Reply With Quote
Old 10-22-2007, 05:16 PM   #12
You can buy it here for $45.95. Enter coupon code AXgps for 10% off. Total shipped to CA, had to pay tax, was $50.86.
therealdeal74 is offline   Reply With Quote
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
Mapmonkey 1.1.3 release crashes and exits only when GPS in use UHF MM Bugs 6 02-04-2006 10:22 AM
My GPS scenario & Bluetooth quest. gizak GPS 13 04-12-2005 01:11 PM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
choosing gps, need help... icet GPS 3 10-21-2004 10:11 PM
