07-28-2007, 08:28 PM
#256
Hello All
I have V6 and find it great for general navigation.
The POIs are a bit restrictive though.
Have been able to add speed cameras using GetMef but would like to be able to add other types e.g. LPG sources - Aires etc.
I understand that there are better facilities in V7 for this, are they backward compatible to V6 OR has anyone done any work, on providing some facilities on V6 itself?
Best
Fred F.
PS. Don't think I can afford to go up to V7 as I had only just got V6 when V7 came out - not happy about this at all!!
07-29-2007, 12:28 PM
#257
Quote: Originally Posted by _dopehead_
wow, i have been looking for that for a while, thats awesome, thanks
Seen as RR doesnt have the same interactiveness as FreeDrive/Map Monkey ie: mute sound when a direction is given, will this program allow the same thing to be done with PC Navigator?
Also do you have any updates on the program you made to integrate PC Nav into RR?
Cheers
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
07-29-2007, 06:14 PM
#258
From what i understand, yes it will. i will have to try it out to be sure though.
my little program works like i wan't it to, so i don't know what you would be looking for of an update?
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
07-29-2007, 08:02 PM
#259
as in have you had any problems with it bugs etc?
CarPuter Progress:
07-30-2007, 02:35 AM
#260
Not really no.
07-30-2007, 07:27 AM
#261
ok, looks like ill take the hit and buy v 7 then. thanks for the info.
CarPuter Progress:
07-30-2007, 07:40 AM
#262
i've just had an email back from indievolume who have confirmed that it will do this. I also asked if it would be possible to reduce the volume of winamp to 50% whilst the satnav spoke and they said they would add that in as a supported patch if/when i bought the product. I'm going to get it tonight!!!
i am also going to open a new thread called
"PC navigator 7".
07-30-2007, 07:43 AM
#263
Sounds good, its time for a how-to-do-it thread with pcnav7
07-30-2007, 08:04 AM
#264
01-21-2008, 04:05 AM
#265
Converting gps maps from mef format to csv (garmin format)
Hi, im new in the gps maps business and would like some expert help on the following issue:
I have pocket navingator maps for my country which has a .ttr and .mef formats. I want to convert them to .csv format to use on my Garmin GPS. Is there a program to use and if so where can I find it?
| Thread Tools |
| Display Modes |
Linear Mode
