02-28-2007, 12:53 PM
#46
I've since had this info from Directions. I don't understand "....TCP commend to send destination" but at least we'll have a resizeable window
Graham
Sent: 28 February 2007 15:22
To: 'Graham Diacon'
Subject: RE: PC Navigator 6
new version, where you will be able to size window and TCP commend to send destination
02-28-2007, 04:15 PM
#47
i guess its a step in the right direction when this becomes available.
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
02-28-2007, 06:18 PM
#48
nice software indeed
Reason: nothing interesting to write...sorry
03-02-2007, 02:52 AM
#49
Graham
To: 'Graham Diacon'
I've also asked about the improvements mentioned here in this thread, had this answer;
"Version 7 after CeBIT, end of March/April."
03-02-2007, 09:52 AM
#50
If it's Version 7 rather than 6.nn will they try to charge us in order to get what we should have had in the begining?
Graham
03-02-2007, 12:17 PM
#51
I don't think so, they have released one patch for 6.x and probably won't release any more, since the next release is 7.x. i will be very dissapointed if i have to pay for basic functionality enhancements in a product that was released not that many months ago.
03-02-2007, 02:16 PM
#52
I hope that you're right.
Graham
03-02-2007, 04:40 PM
#53
 i have to say of all the satnavs i have tried, this one takes the trophy for simplest, and most up to date!
has anyone had any success in embedding it (apart from the full screen when the 'menu' is pressed) into road runner, ive made a skin, and added a application/clipping area, it loads, but i have touch the application area to be shown, what code are u using? im using this, a button from the main skin file:
B,000,250,200,050,"LOAD;pcnavigator.skin;GPS;C:\ Pr ogram Files\PC_Navigator6\PC_Navigator.exe;Navigator 6",""
pcnavigator.skin has the following code to embed:
A01,204,42,596,516,192
C01,204,42,596,516,192
i think my code is ok, just want to know if anyone else has done anything better.
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
03-04-2007, 07:29 PM
#54
Also...
Has anyone had any success in importing POIS to it as well?
Cant seem to see any where in the folders that contain the pois!
CarPuter Progress:
03-05-2007, 07:01 AM
#55
is there any demo available for this, or do we have to buy it to try it
03-05-2007, 07:25 AM
#56
for now i think buy, then try :-(
Embedding this application is kinda pointless until it can be resized, the problem with the application area is that you are missing an area of the actual application window, in my tests i have been able to embed it just fine in a smaller area and then have menu's around it, but you are actually just covering part of the application.
Reason: Automerged Doublepost
03-05-2007, 08:36 AM
#57
buy, then try, then cry
03-05-2007, 12:14 PM
#58
Quote: Originally Posted by jonessc
Also...
You need to read the section on scout warnings in the help file.
Basically what I did was convert a speedcam.csv into an .xls file with excel, then use a program called getmef.exe located on the installation media to convert this file into a .mef file called cat999.mef
this file needs to be placed in the europe_ta folder.
www.matt-tech.co.uk In Newcastle upon Tyne and Tyne & Wear
PC & Network : Installation, Service, Repair & Support
03-05-2007, 04:16 PM
#59
superb, il take a look... i was searching for pois, didnt realise they called it scout
ta!
CarPuter Progress:
03-08-2007, 02:46 PM
#60
Would anyone be willing to post a copy of their cap999.mef file? i'm running vista and the getmef application crashes after importing the XLS data I have. failing that, would anyone be prepared to convert my data into an mef file?
I must say that I like the way navigator 6 has gone, I was a user of prymenav for years but this is a real step forward for people who use touchscreens.
EDIT:
Managed to get something in via DBF import rather than XLS. quick question. what are the references to N1 for longitude and latitude for? I have data that looks like this.
GATSO :1070@50 53.560080 -2.405122
GATSO :1073@50 53.549775 -2.385684
GATSO :126@50 53.375489 -2.379942
GATSO :13267@50 51.829022 -2.368820
and i'm picking geographical dd.dddddd from the getmef program along with N1 long and lat.
Are my cameras placed correctly or are they on the far side of the earth?!
Regards,
Mat
| Thread Tools |
| Display Modes |
Linear Mode
