There is no way to know. Depends on the particular unit, and the wiring diagram isn't much help. If you can find a part number of the actual GPS module, someone might be able to help. The signals could be in serial, TTYL, or some sort of proprietary form. I doubt you have scope to check, so the best bet is to find someone who can tell you because they have as scope, or someone on the net, or by doing some research on the part number of the module when you get it. Also, the GPS antenna might be just that, and antenna, and NOT A RECEIVER. The antenna could be an active powered antenna, hence the GPS ground mentioned. Of course, that could also just be a signal ground. Like I said, you have not provided enough information.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
