Michael,
sorry I wasn't being clear. I'll try to provide as much info as I can.
My OS is XP professional with sp1 installed. I'm currently testing everything from my laptop. I've read many incompatabilities of navigation softwares and frontends, that's why I'm testing the navigation software in stand alone mode. (by itself only)
Last night, I installed the bu-303 with the Prolific driver and the windows reads the gps receiver fine. Streets & Trips 2007 also recognize a gps receiver through the communication port (I tried to change from one usb port to another, the software recognizes everytime).
When I go into gps tracking mode, the software was receiving the data from the gps, but it tells me that the number of satellite is ZERO.
My gps receiver was right by an open window with only either a glass window or a windscreen as the interference.
I did some search and "baud rate" was mentioned, therefore I changed the rate from 9600 (default) to 4800 (as recommended). Everything was still the same, zero satellite.
I have no idea what FE is, so I can't tell you if I'm using that or not.
What else can I do to check to see if my gps receiver is properly working? Is there any software out there I can use?
