Old 11-10-2006, 11:38 AM   #1
Which PocketPC do you recommend for GPS?
I love my carpc with GPS navigation but often I find myself in other vehicles when taking trips. When I look at my iGuidance 3.0 software I noticed it supports PocketPC too and I thought this might make a nice portable alternative. So the question is which PocketPC would someone recommend if I want to run iGuidance on it?
I have a USB BU-353 GPS, but I speculate I might have to buy another GPS device for the PowerPC.
Any cheap recommendations I can buy on ebay?
BlackStealth is offline   Reply With Quote
Old 11-10-2006, 12:28 PM   #2
I haven't looked at PocketPCs in a long time so I don't know what is currently available. I did this three years ago with a Dell Axiom. I chose it because it had both a CF slot and an SD slot. The CF holds the GPS and the SD holds the maps. I also use marine chartplotting software on it for my boat and it works pretty well. My recommendation would be to find something with the biggest screen and the most slots.
Ceasar_Choppy is offline   Reply With Quote
Old 11-11-2006, 01:05 AM   #3
Fusion-One's Avatar
Dell Axim x30 High (624mhz)
Fusion-One is offline   Reply With Quote
Old 11-12-2006, 06:28 PM   #4
F2504x4's Avatar
I own a X51v 624 Axim, and using IG3 with a blue tooth GPS 236 slim by hulox and it works flawlessly, Visit Aximsite and search there threads on this.
You can buy CF adapter so that you can use your current cabled GPS , i did this when I got the MicroSoft Streets and trips with the ppc GPS , but i got tired of plugging it in when ever I got into my truckso the bluetooth was the answer.
If you do go with a BT GPS be sure to look for one with a hard on/off switch so you can hardwire the power cable and not worry about recharging it.
I just hit the BT switch on my AX and the software and away I go.
link to what i'm running
http://www.buygpsnow.com/iguidance-3...mount-469.html
BTW the AXim I got will run you about 300ish not the cheapish but you can do so much with it and even turn it into a moblie carputer.
F2504x4 is offline   Reply With Quote
Old 11-13-2006, 04:10 AM   #5
rotarypower101's Avatar
The xv6700/ppc6700 will do this apparently with IG3, but I have heard there is a slight conflict with push email and voice/action timing
rotarypower101 is offline   Reply With Quote
Old 11-18-2006, 11:43 PM   #6
sviyer's Avatar
The HP iPAQ 6965 is a great device. It has in built GPS. I own one. Quite happy.
Ford Fusion +
Car PC Status - 80 % Complete
sviyer is offline   Reply With Quote
Old 11-20-2006, 03:38 AM   #7
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
Or, if you want a slightly older version of the same phone, get the HP 6515. It comes with a GPS receiver in the PDA. It's a Phone also....
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is offline   Reply With Quote
Old 11-20-2006, 06:42 AM   #8
forget 6515, acqusition time took too long and having problem acquiring gps signal in the car..
skuller is offline   Reply With Quote
Old 11-20-2006, 11:14 PM   #9
JimmyFitz's Avatar
I have used my XV6700 to run IG3 with a Bluetooth GPS and it works fine. I don't know about the conflicts mentioned because I don't use push services.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
PocketPC & Carputer i3igmind Input Devices 13 10-31-2007 08:27 AM
PocketPC FrontEnd in the making! mrobert Coders Corner 32 09-28-2007 09:58 AM
PocketPC as a Touch Screen Replacement sama Other Cool Front Ends 59 08-05-2006 05:53 AM
WTTF : PocketPC ukchris Classified Archive 0 11-16-2005 08:52 AM
After reading the FAQ, have some questions - what would you recommend? ABTsportsline Newbie 2 10-20-2005 08:42 AM
