Old 11-17-2006, 09:07 AM   #1
MySQL Error
Sonicxtacy02's Avatar
my iG3 keeps clearing the route
i dont know why this is occuring. First lemme show my setup
iguidance umpc using multiple instances of the .exe (hacked versions, regular versions)
Running embedded into rr freedom 2.1 skin, ignative=true.
What happens is i'll set a route then go out of the iguidance screen (like back to menu). at random times the route auto clears without warning. I'll go back to the iguidance screen and iG is still running, just without a route. Anyone have any idea what this is. I thought it was maybe some clear route hotkey being triggered by something but i dont see a hotkey for clearing a route. As i said above i've tried a few different .exe's and they all act the same. tried to uninstall and it still does it. What gives?
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
Developer of: RRFusion, MovieTimes, (new)RRMail, & RR Plugin Manager
Coming Soon:RRChrome, & CentraFusion
Is Your RR Plugin Managed?
Old 11-17-2006, 09:59 AM   #2
MySQL Error
MatrixPC's Avatar
Weird. I have no problem with that.
I am also running 2 different instance of iG3 regular and umpc. UMPC version is hack (change caption to iGRoutis). The regular version is running embedded in RR (ignative=true) with my mod CFX skin. UMPC is running on the 2ndary monitor (back seats).
The only problem I have when running at that configuration is I have to use 2 separate COM port for both. By default, both read the same COM port and that cause refresh/update problem (delay). I have to change the COM port on UMPC after the app run.
Normally, I set a route for regular version, the fire up UMPC, change COM port, disable volume.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Centrafuse & IG3 sound TSXPC Centrafuse 5 09-08-2006 04:26 AM
IG3 Menu Screen Malfunction Tensai GPS 5 08-31-2006 02:02 PM
NAV change request/feedback: CNavRouteTypeModule shouldn't show route options S4Per StreetDeck 0 07-07-2006 05:11 PM
Drop-down menus don't work? Read this! gnomad Announcements 0 10-14-2005 02:15 PM
FD 0.82 update CdRsKuLL FreeDrive 43 07-27-2005 07:34 AM
