Old 11-24-2006, 11:25 AM   #1
Vorex's Avatar
Vorex is on a distinguished road
Lightbulb GPS Software Comparison Chart
http://www.mp3car.com/wiki/index.php...mparison_Chart
I am only familiar with a handful of these programs, does anyone see any errors?
- Vorex Out
Vorex is offline   Reply With Quote
Advertisement Sponsored links
Old 11-24-2006, 11:43 AM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
well derstinator and iGuidance doesn't take account of what different versions offer.
eg
iGuidance v3 does not have maps for Europe.
Mappoint has an OCX which frontend developers can use to access. RoadRunner does this.
Destinator 3 has a SDK and depending on which version (FreeDrive, MapMonkey, GaroNav to name a few) offers very good communication to and from.
Enforcer is offline   Reply With Quote
Old 11-24-2006, 02:23 PM   #3
Vorex's Avatar
eg
I think made the right fixes, do think D3 should be broken down so theres 3 different ones, like one for FD, one for MM, and one for GaroNav?
- Vorex Out
Old 11-24-2006, 02:51 PM   #4
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Awesome piece of work!
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 11-24-2006, 02:55 PM   #5
sama's Avatar
sama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud of
rerouting based on traffic support? Destinator PN does
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 11-24-2006, 03:12 PM   #6
A couple things I noticed:
CoPilot is touchscreen friendly, at least the one version I saw was. I believe that was v7.
StreetDeck does have European maps available, although teh development isn't as robust as the North American version.
A couple of other features that would be worthwhile that aren't in your comparison chart:
- Multiple waypoints or stops
- Auto-start of GPS
- Trip logging capability
- Ability to import custom POIs (like speed cameras or favorite locations)
Also, it may be useful to indicate versions of various software. It's likely that most would use the most current version of software (Streets & Trips 2006, for example), but notations could be made which version first included a particular fweature or function.
Old 11-24-2006, 03:17 PM   #7
Vorex's Avatar
thanks, i'll be doing a few more charts, people shouldn't have to try half a dozen frontends to see what their feature sets are...
PN?
- Vorex Out
Old 11-24-2006, 03:20 PM   #8
Confusion Master
Enforcer's Avatar
PN?
Destinator 5 uses PN maps. I think version 6 will as well.
It's also worth noting that the destinator version that centrafuse will be running will be version 6 but won't work with the standard destinator maps.
Old 11-24-2006, 03:32 PM   #9
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
One correction, two comments.
Delorme does do rerouting: it has a user defineable variable distance from suggested turn that triggers the recalculation of the current route.
You may consider adding another row for SDK. This is a prime motivation for some of us using Destinator because it allows the front-end to not only send commands to the nav software but also incorporate nav data into the front-end. (The one sorely missed option of IGuidance).
You may also want to add a row for map date or make it a parenthetic for the maps checkbox.
The two comments above highlight another problem with Destinator development, i.e., D3 SDK is outstanding, however, D5&6 SDKs are currently unuseable and this info would have to be footnoted on the SDK row.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 11-24-2006, 03:46 PM   #10
Vorex's Avatar
- Auto-start of GPS
I believe I got the majority of what you said added, I don't know the differences between different versions of these programs so I can't do that stuff myself These rows are blank for the most part until someone clues us in.
I'm still on iG 3 and D3
- Vorex Out
Old 11-24-2006, 03:51 PM   #11
Vorex's Avatar
Done, I don't know the map data dates...I think we could incorporate the dates into the same row as the maps line, or next to the check boxes for regions.
- Vorex Out
Old 11-24-2006, 08:43 PM   #12
GizmoQ's Avatar
Delorme autostarts and has trip logging, but no SDK/API.
Old 11-24-2006, 09:54 PM   #13
Vorex's Avatar
Done, thanks
- Vorex Out
Old 11-25-2006, 10:35 PM   #14
djmadfx is an unknown quantity at this point
Wow, nice chart! How come there's no TomTom listed for us PPC users.
djmadfx is offline   Reply With Quote
Old 11-26-2006, 08:07 AM   #15
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
Nicely done! You could remove Routis to gain some space. Routis exists no longer. It stopped at version 1.1 some two years ago. At that time it was a re-branded version of iGuidance 1.1. iGuidance lives, Routis is dead.
Marvin Hlavac is offline   Reply With Quote
AUSSIES!!! GPS software for PDA krbz GPS 2 05-26-2006 07:47 PM
FREE GPS Software? ikhonlord Newbie 2 11-04-2005 12:39 PM
GPS Software with personal P.O.I. Iguidance? Or? claudioita Software & Software Development 1 08-17-2005 04:19 AM
Best GPS software for carputer? dazuck GPS 13 03-10-2005 10:52 AM
Wtb: Gps Software And Gps Mouse!!!! HitmanZ Classified Archive 2 08-03-2004 10:56 PM
