The MP3car.com Store
Thread Tools Display Modes
Old 12-23-2006, 04:24 AM   #1
ShowGPS's Avatar
My Photos: (0)
Arrow ShowGPS - allround CarPC tool with POI Warning
Now a new version of ShowGPS is available!
Version 2.58 in good english.
Download ShowGPS 2.58 with POI Warning
Features
Mini-POI-Display for every navigation program
LOG-file evaluation for Google Earth
Autoswitch to Navi-program on voice output (NCK5 / M&G fleet navigator)
Sound and voice output for all information
Touch screen menu
Points of interest notification and import
Pause your player when voice output
Automatically measure acceleration
With the virtual port you can share your gps-port
Volume automatically adjusts
RDS Radio Text information
Graphically see your speed and altitude
Controls the brightness of your screen
Can start automatically other programs
Built in Winamp and Media player support
Automatically locates your GPS device
And many more...
http://www.showgps.com
ShowGPS. GPS/POI/Map Tool for every Notebook/CarPC - http://www.showgps.com
ShowGPS is offline   Reply With Quote
Sponsored Links
Old 12-24-2006, 07:22 PM   #2
LiquidKernel's CarPC Specs
LiquidKernel's Avatar
Vehicle: 1995 Volvo 850 T5
My Photos: (0)
Looks good! Thanks for the update.
95 Volvo 850 T5 • Konis • ECU @ 17psi • 5+20% Tint • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • 2.5" BOSCH HID Projector Retrofit
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 03-14-2007, 04:24 AM   #3
ShowGPS's Avatar
My Photos: (0)
ShowGPS 2.60
Hello!
Now ShowGPS 2.60 is available!
New Features:
Statistic with graphic chart analysis
RDS/TMC modul can attached on own port
A Icon for ShowGPS is always on top (for Touchscreen)
Download, screenshots and more informations on www.showgps.com
Regards,
ShowGPS
Old 08-09-2007, 05:25 AM   #4
ShowGPS's Avatar
My Photos: (0)
Arrow ShowGPS 2.64 BETA
Hello!
For all people the use Navigon NavigatoR 2.0 or Mapfactor/Directions PC-Navigator 6/7.
Now ShowGPS can export POIs directly to these programs.
With a few clicks you can synchronize your pois and have a active warning with showgps and the display in your program.
More new features:
- Mapview, see your position on the world and all pois in your distance
- Filter in the poi-window, see only your favorite pois
- and more...
Information and Download on http://www.showgps.com
Regards,
ShowGPS
Old 01-02-2008, 01:59 PM   #5
ShowGPS's Avatar
My Photos: (0)
Arrow ShowGPS 2.68 - Trial Version
Hello!
Now, you can test ShowGPS as trial version!
New features:
POI categorys
Now you can sort your pois in different categorys.
POI multi-import
With this function you can select many poi-datas to import.
POI Import/Export
POI Export for Navigon NavigatoR 2.0+NCK5* and MapFactor Navigator 6+7
With a few clicks your can export the POIs from ShowGPS to your navigation program. No workaround, no grind. Simple with ShowGPS. All pois now as category in navigon.
*for NCK5 you must have the poiimportconsole from navigon
Filterfunction for POI-Window
Now you can filter the POIs with a text string.
The last searchs are saved.
Regards,
ShowGPS
Old 03-03-2008, 05:12 PM   #6
ShowGPS's Avatar
My Photos: (0)
Arrow ShowGPS 2.70 - GPS/POI/Map-Tool - Shareware
Hi!
Now ShowGPS 2.70 as shareware is available!
Download http://www.showgps.com
New Features:
Mapview and City-search with Worldmap
The Mapview shows your position on the world or the imported maps.
You can see worldwide cities and your POIs from ShowGPS on the map.
Map import via Openstreetmaps and Expedia
Install OSMTileDownloader or MapCalibrator
-> go over ShowGPS "Map" -> "Map view" and zoom to the region
-> "Map Download" and follow the help
New Startmenu
Quick Start menu for the main functions, 6 large buttons allow direct access to all major functions
Regards,
ShowGPS
Old 03-07-2008, 08:12 AM   #7
gradecak's CarPC Specs
My Photos: (0)
Hi
I'we got ShowGPS couple days ago , looks good so faar , I'm usig Navigator 7 Europe , as Frontend RR and CrystalBlue skin, is it ShowGPS capable to render map from Navigator 7 and if not what maps are the best to use .
Regards
Ivan
gradecak is offline   Reply With Quote
Old 03-16-2008, 03:10 PM   #8
ShowGPS's Avatar
My Photos: (0)
Arrow OpenStreetMaps or Expedia
Hello!
ShowGPS can only use bitmap maps, not Navigator 7 maps.
When you have a screen resolution of 1024x768, then you can use the OSMTileDownloader to use the maps of OpenStreetMaps.
Otherwise you can install MapCalibrator to download maps from expedia.
Under ShowGPS you can go to >Map-View and on >Map Download
More informations on http://www.showgps.com/download.php
Regards,
ShowGPS
Old 05-06-2008, 02:10 PM   #9
ShowGPS's Avatar
My Photos: (0)
Arrow ShowGPS 2.72 - with geocoding, for only 9.90 euro
Hi!
Now ShowGPS 2.72 for only 9.90 Euro!
New Features:
Simple Geocoding over Internet
Make your addresses to POIs
Big warning picture for POIs
Set your own picture for display over the hole screen
Online-Tracking with OpenStreetMaps
For every ShowGPS User are 100 values free to save.
More about this function: http://www.showgps.com/gpstracking.php
Regards,
ShowGPS
Sponsored Links
vB code is On
Trackbacks are Off
Invalid Argument tn6478 StreetDeck 20 12-30-2007 08:02 PM
1.0.4.7 bug debugger StreetDeck 9 07-01-2006 03:01 AM
Finally finished CarPC install and trunk Bandwidth Warning! 04scooby Show off your project 14 07-26-2005 07:30 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
