Hi,
I have downloaded pois for map monkey, that get listed as favourates with sub categorys (.dat files).
When you select a POI it lists them in distance from current position, as favourates just lists them in alphabetical order, which would take weeks to select which one to select.
Is there a way to get the favourates to be listed in distance order, like the POIS get listed? i see that there is a file that has a .poi extension but cannot find any tools to edit it.
I did see through searching forums that someone made a plugin for map monkey to do a similar thing, but all the links are dead, and the post was back in 2005.
Anyone got a solution?
someone posted a similar question, but doesnt appear to have had a reply:
http://www.mp3car.com/vbulletin/show...destinator+poi
thanks!
