Old 01-26-2007, 06:48 PM   #1
lucky1's Avatar
lucky1 is an unknown quantity at this point
Unhappy BU-353 Problem
Thanks for all help in advance.
I have the BU-353 receiver, and I cannot get it connected, I think that it is because I don't have the VCP, I have loaded the included drivers from the disk that came with it, that didn't work, went to the web site downloaded that driver that didn't work either.
I think that when I go to the device manager I should see, prolific serial to USB comm port. I am not seeing this. also when I pug the receiver into the USB slot, windows XP does not say found new device, maybe that is the problem, or do I just need a new receiver.
Lucky 1
lucky1 is offline   Reply With Quote
Advertisement Sponsored links
Old 01-26-2007, 07:15 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Are all the USB ports enabled in the BIOS?
Yes, you should see Prolific USB-to-Serial in the device manager.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 01-27-2007, 02:21 AM   #3
darksideofjae is on a distinguished road
Im having a similar issue. But mine is related to cold weather. It seems with the recent cold weather my BU-353 wont be detected by iGuidance. So what i did was take it inside the house when i get out the car and in the morning plug it back up and fire the PC up and sure enough iGuidance detects it. Maybe this could be your issue. Has it worked before? Also if so, do you see a pattern or is it just sporadic
Hope this helps
darksideofjae is offline   Reply With Quote
Old 01-27-2007, 11:39 AM   #4
lucky1's Avatar
ok
But I don't think thats the problem, my garge is not that cold inside and it doesnt work there either.
Thanks anyway
Old 05-23-2007, 06:45 AM   #5
keygen is an unknown quantity at this point
does other usb devices work ? and did you try to install the mouse to any other pc to be sure if it is working or not?
keygen is offline   Reply With Quote
Old 06-01-2007, 12:03 PM   #6
john05srt4's Avatar
john05srt4 is an unknown quantity at this point
Same problem. Just installed it new from box yesterday. Worked great.
Got in car later turned PC on and it doesnt detect it at all?
tried other usb ports, nothing, tried to reinstall drivers, nothing?
im trying to use streets and trips 06 or the OEM gps config CD. Neither detect it.
and no its not cold.. 75 degress and hasnt gotten wet?
My Accord CarPC
john05srt4 is offline   Reply With Quote
Old 06-07-2007, 12:05 AM   #7
carbon is on a distinguished road
I'm having the same issue with the BU-353. Other USB devices work on the same port, but the receiver isn't detected when connected. Any ideas?
carbon is offline   Reply With Quote
Old 07-12-2007, 04:15 AM   #8
jgdynamics is an unknown quantity at this point
im having a similar problem maybe, one time it wasnt detected so i had to re-install the software, but now it doesnt even get a signal, maybe its because i moved it to under my passenger seat... could that be to low or too much blockage?
jgdynamics is offline   Reply With Quote
Old 07-12-2007, 09:37 AM   #9
john05srt4's Avatar
i sent mine back as defective..it worked fro 5 minutes moved it to another usb and dead on 3 different PC's.
new one has been working great and moved it with no problems.
My Accord CarPC
Old 07-12-2007, 09:46 AM   #10
tracker64 is on a distinguished road
if you don't set the BU-353 at 9600 baud you WILL NOT get any output and it will not work at all until you set it at 9600 baud, in port properties and in GPS application software...
tracker64 is offline   Reply With Quote
Old 07-12-2007, 10:37 AM   #11
john05srt4's Avatar
Yes but the PC will not even detect the device is plugged into a USB port so you cant change the settings.
My Accord CarPC
Old 07-12-2007, 10:55 AM   #12
it'll detect as a com port, not as a GPS device.
can you verify this?
Old 07-12-2007, 01:11 PM   #13
john05srt4's Avatar
No mine would not even show as ANY type of device..
My Accord CarPC
Old 07-12-2007, 05:18 PM   #14
brodgar is an unknown quantity at this point
Am I doing something wrong? I have mine set to 4800, ( I can't find the instructions now but I'm certain that is what it said to do ). At present mine is working perfectly
brodgar is offline   Reply With Quote
Old 07-12-2007, 05:46 PM   #15
GiODi will become famous soon enough
It should be 4800.
So does the Prolific USB-Serial show up under Ports (COMS & LPT) in the device manager?
GiODi is offline   Reply With Quote
reconnected puter and now audio problem.. NYCdesignkid Car Audio 2 05-31-2006 12:09 AM
gps navilock and com problem lele67 GPS 0 04-01-2006 08:41 PM
Problem with directshow filter and WMP EricE Software & Software Development 0 03-01-2006 11:38 AM
Car Idle - power/amp problem? TheFaze Car Audio 1 12-16-2005 12:10 AM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
