Quote: Originally Posted by
c5ho
Hmmm...perhaps I will do some more testing with my mouse GPS module. Hey bimmerman, when you say you mounted it to a flat ground steel, was it under the hood then or still in the cabin?
Personally I placed it underneath the fabric that separates the trunk and the main cabin (below the rear window). In my Audi there is a large metal sheet with holes in it. I passed my gps thru there from the trunk and magnetically stuck it to a good clean flat piece (make sure there is no sound deadoning material). From here it was completely hidden, even from the trunk and it still had good reception.
Of course the easiest way to test would be to mount it exactly in the middle of your roof or trunk outside the car. This will give you the best possible ground plane and then you can begin moving it to "easier" places and watch the performance. If it still hasnt improved, then you need to start looking to other problems. It will at least give you an idea of whether it is a ground plane issue or something else.
