Old 07-28-2002, 05:25 AM   #1
C4M
C4M's Avatar
A simple GPS solution
God bless the internet!
I really didn't want a regular screened GPS like those from Garmin - I just wanted an antenna that could supply the appropriate output.
Appears that this one just plugs into the USB port (and therefore has no other cabling requirements), and everything else is just software:
http://www.laipac.com/products/gps/G10.htm
Price is USD$125 (+ shipping)
Is anyone else using one of these? Are they as simple as they look? How many seconds after getting it did you hit it with some paint to kill that nasty silver colour? :-)
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
C4M is offline   Reply With Quote
Old 08-05-2002, 09:47 AM   #2
spyhunter's Avatar
i'm currently using the delorme gps - earthmate....its pretty good for about the same price, accept the supported software is a bit limited
Alex
90 300zx twinturbo conversion
Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
spyhunter is offline   Reply With Quote
Old 08-18-2002, 04:42 AM   #3
C4M
C4M's Avatar
Quote:
I think the one that I linked above just outputs std NMEA sentences, and also collects its power from the USB port, which means no more masty batteries...
C!
Old 08-18-2002, 08:07 AM   #4
spyhunter's Avatar
yup the earthmate sends in rockwell binary formatand a usb cable is available. the software is pretty good though. my car talks to me and tells me where to go
Alex
Old 08-18-2002, 09:18 AM   #5
C4M
C4M's Avatar
I don't need that; I'm married
C!
Old 08-18-2002, 10:14 AM   #6
Skippman's Avatar
LOL
Stereo:Alpine IVA-D900 Head Unit | Alpine PXA-H510 DSP | Boston Pro Component Speakers Upfront | Boston Rally Rear Speakers | 2 Polk 10" Subs in the Trunk | Phoenix Gold Ti900.7 Amp
Skippman is offline   Reply With Quote
Old 08-18-2002, 12:25 PM   #7
DOH
I hear you on that one C4M.
They also have a serial version that uses a cigarette lighter plug for power. (Look at the spec chart to the right of the page.)
Seems like it was designed specifically with car use in mind.
AVGeek is offline   Reply With Quote
Old 08-18-2002, 09:26 PM   #8
jpainter99's Avatar
I bought one of these. It speaks standard NMEA etc. I know for a fact it talks to delorme. Very good deal at only 99$
http://www.deluo.com/Merchant2/merch...tegory_Code=GR
jpainter99 is offline   Reply With Quote
Old 08-19-2002, 05:40 AM   #9
C4M
C4M's Avatar
The specs on this one are pretty much the same as the one I linked above, and it's $30 cheaper. w00t! As if I needed any further persuasion, it's not silver!
/me hopes that they ship outside the USA...
C!
Old 08-19-2002, 07:11 AM   #10
have you thought about maps? i couldn't find any for australia when i looked
kardas
http://austmp3car.tk
kardas is offline   Reply With Quote
Old 08-19-2002, 10:57 AM   #11
Registered User
I didnt think there were roads in australia ... a la Mad Max.
mxxxxxm is offline   Reply With Quote
Old 08-19-2002, 05:38 PM   #12
C4M
C4M's Avatar
Quote:
And driving to work in Sydney takes forever, what with the traffic and dodging all the kangaroos that are running wild down the street...
Old 08-22-2002, 09:59 AM   #13
C4M
C4M's Avatar
C!
They ship outside Australia - w00t!
Deluo GPS
Anyone in Australia considering GPS and want to split the shipping costs? (Kardas? Magnetik?)
Should be able to get three without incurring the wrath of our friends in Customs and the ATO
PM me if you're interested. I'm ordering next week...
C!
Old 08-23-2002, 09:30 PM   #14
Stick with the Garmin GPS35 or GPS16.
Just an antenna, but a top notch one. Garmin makes good stuff. Quick locking, modifiable behavior (choose what string come out), battery backed up, runs off car voltage, ruggedized, etc. etc.
I have a GPS35 and it works great. The GPS16 is basically the same thing, but slightly improved and with WAAS support. If I was repurchasing now, I'd get the GPS16 (wasn't out when I bought), although the GPS16 might require you to solder on a serial connector to the wires, whereas the GPS35 comes prewired.
Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
Car: 1993 Nissan Maxima, Black Emerald
jshrieve is offline   Reply With Quote
Old 08-25-2002, 09:57 AM   #15
C4M
C4M's Avatar
I looked at the site, and the Garmin does look good. However:
* the ones linked above only require a USB connection (I only have one serial port, and it's busy)
* they take their power from the PC, meaning that there is only one cable necessary
* I only need std NMEA sentences for the software packages I plan on running
* I suck at soldering
C!
