Old 03-01-2007, 05:54 PM   #1
Grimoire's Avatar
Grimoire is on a distinguished road
Odd BU-353 problem.
So, I have IGuidance 3.0 and the BU-353. Now, I installed the USB to Serial drivers, and the BU is flashing the red light. I dont know if its supposed to flash or be solid light. But I have no info off of it. When I load IG I am 10 miles away from my house, and when I drive with it, I dont move. At least, the software says I dont. The Lat and Long are there, but I have no way of knowing for sure if its right. The Alt is not there neither is the speed. Also the first two fields are also blank. So, anyone have any Ideas? Is my GPS working and Im just an idiot or is the gps reciever dead? Thanks.
Grimoire is offline   Reply With Quote
Old 03-02-2007, 08:40 AM   #2
Mr_Civic's Avatar
Mr_Civic is an unknown quantity at this point
The flashing red led stands for position fix. This has happened to me. Try unplugging the usb cable, waiting 10-15 seconds and re-connect it to see if that helps.
Alex
Progress: 91% (Cosmetics) @ Stand Still...
CarPC specs are BACK!! Edit yours today...
Mr_Civic is offline   Reply With Quote
Old 03-02-2007, 12:53 PM   #3
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
LED OFF: Receiver switch off
LED ON: No fix, signal searching
LED Flashing: Position fixed
kevinlekiller is offline   Reply With Quote
Old 03-02-2007, 01:03 PM   #4
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Go into the IG menu and select it to "auto" find the GPS. Maybe it never found your device. Did it ever work or is this the first time you are trying to use it?
System always under construction
durwood is offline   Reply With Quote
Old 03-02-2007, 05:34 PM   #5
Grimoire's Avatar
This is the first time ive tried using it. Whats the "Position Fixed" Status mean? Thanks for the help, Ill try to set it to auto and see if that works.
[edit]
It was set to Auto and still it blinks. Unplugging it and plugging it back in also doesnt work. Im still not plotting.
Problem with directshow filter and WMP EricE Software & Software Development 0 03-01-2006 11:38 AM
20x4 Problem - Odd charcters and layout is_this_easier LCD/Display 4 02-26-2006 08:13 AM
Car Idle - power/amp problem? TheFaze Car Audio 1 12-16-2005 12:10 AM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 12:50 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
