Old 03-01-2007, 07:48 PM   #1
lord1234 is an unknown quantity at this point
grayed out satellites
All of the satellites my GPS is hooking up to seem to be grayed out. I can't get a signal from any satellite. I do get a time signal, but I can't get a location signal.
I am using Iguidance 2.1.3 and running a Holux GR213 reciever on Com3 at 4600 baud. OS is Windows XP, all proper drivers are installed. I even tried reinstalling them! Reinstalled Iguidance.
Any suggestions? As a side note I also noticed that in the past the light on the GPS reciever used to blink, and now it just stays solid orange.
--L
lord1234 is offline   Reply With Quote
Old 03-01-2007, 07:53 PM   #2
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Wiredwrx has a little shameless behaviour in the past
--L
Where is your receiver located?
Michael
Wiredwrx is offline   Reply With Quote
Old 03-01-2007, 07:58 PM   #3
whether its roof mounted, or mounted internally on top of my scooby's dash(right dead center between the two heating vents) same results. It worked for a period of time...and then it just stopped I dunno why...
Old 03-01-2007, 08:20 PM   #4
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Are you able to see what data is actually being passed through the COM port? If you see NEMA stuff, then the GPS is fine and the problem is software. If you don't then most likely hardware.
Old 03-01-2007, 08:24 PM   #5
I see some stuff being passed...it is able to collect the "exact" time...however then it is UNABLE to get any location information.
Old 03-01-2007, 08:36 PM   #6
DJiK's Avatar
DJiK will become famous soon enough
It's a GR213 thing...
Basically it has something to do with the internal locking battery/chip combo.
Find the configuration software on the Holux Website and see if it works 2 mins after doing a Cold Start.
It should...
The Software.
It's called GPSViewer. Try it out in your car, it's gonna have the three Start options.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Can't get BU-353 to find satellites Boxxman GPS 8 04-01-2006 08:18 AM
Embedded Programs - Grayed Out Upon Return kbreeden CF Bug Reports 1 08-25-2005 10:30 AM
GPS Losing satellites when behind windscreen ShawJohn GPS 4 09-14-2004 03:42 PM
Hibernate and standby grayed out?!? kefka_killer General MP3Car Discussion 12 08-19-2004 10:33 AM
Globalsat BU-303 USB - cant find satellites Hitman GPS 14 07-12-2004 06:23 AM
