Old 03-05-2007, 02:51 PM   #1
EricE is on a distinguished road
IGuidance 3.0 and Embedding RR
I am getting my GPS receiver tomorrow and a couple of days ago I installed iGuidance 3.0 and have been playing around with how to make it work adequately in RR. I have figured out how to embed iGuidance into SKINbedder and Autoit and even IGmon. From what I can tell all of these were made for a previous version of iGuidance and that they don’t work well with 3.0 (or seem to be needed)…Is that assumption correct?
So far I seem to be fairly happy with the stock functionality of iGuidance 3.0 and I may not need much more than it provides. What I do want though is a way to embed it into RR such that I can switch back and forth between it and my tunes. If I embed it into RR using External (and no skinbedder or anything else) then I find that iGuidance closes when I try and go back to my audio player. Is there a way to solve that? I am fine with editing my current skin to do what I need.
Since I am new to the GPS problems I don’t know how hard it is to solve what I am asking for. Can anyone point me in the right direction?
If you care to make any other observations about problems that I will need to solve then I am listening.
EricE is offline   Reply With Quote
Old 03-05-2007, 03:12 PM   #2
volum3rider is on a distinguished road
Roadrunner supports imbedding Iguidance internally wihtout any other programs. As for your problem with switching songs and keeping your Iguidance open, you can place a next and previous button like in the picture.
or you can add an exit/close button that does not close the gps program but returns you to your desired screen to switch between songs.
What skin are you using anyway?
volum3rider is offline   Reply With Quote
Old 03-05-2007, 03:24 PM   #3
I am using a modified version of Triton. I did embed iGuidance into RR with no other programs.
When I say switching I mean I would like to be able to switch to the audio_player screen while iGuidance runs in the background. I assume if I do this then iGuidance would still warn me of approaching turns and such and that is what I want. Then I could pop over to the GPS screen to view the map.
So how would I make a button that would pop me over to the audio_Player screen w/o closing iGuidance.
Old 03-05-2007, 03:35 PM   #4
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
I thought iGUidance closed at first also , but it was only a visual bug , if you click anywhere and drag ( where the map is suposed to be ) the iguidance will appear.
Oh I see what you mean... Im not sure then.
Last edited by kevinlekiller; 03-05-2007 at 03:36 PM.. Reason: Automerged Doublepost
kevinlekiller is offline   Reply With Quote
Old 03-05-2007, 04:06 PM   #5
No, you are correct. It is a display bug. Playing around at work here I embedded calc.exe. I can load numbers into the buffer and switch back and forth and when the calc comes back up it still has the number in the buffer. SWEET. Thanks so much. I am half way there now.
Old 03-05-2007, 04:41 PM   #6
Another thing you can do is make a button that links to a command on iguidance ( like JohnWPB does in his DigitalFX skin ; check his external_gps.skin file )
Old 03-05-2007, 09:47 PM   #7
ok, that display bug is killing me. When I switch back to the GPS...it is not there . I have to click and drag a small amount to make it show up. Any way to solve that? If I embed it with a blank (no buttons) skinbedder will that solve that?
Never mind. I am thinking this is only a problem because I am testing in my driveway. If I were moving I suspect that iGuidance would be constantly updating and as such it wouldn't be blank for long.
Old 03-06-2007, 06:48 PM   #8
jjnit's Avatar
jjnit is an unknown quantity at this point
LOL - I was curious about the same issue so I just found this thread. You are in fact, correct. Any update of the screen (i.e. the scrolling map while driving) makes it show back up. In the brief second or so it takes to do that on mine I just see through to my desktop.
GeorgiaCarry.org Member
jjnit is offline   Reply With Quote
iGMon - Solution for integration between iGuidance and Road Runner (I hope) b8bboi RR Plugins 570 11-05-2009 03:49 PM
Frustrated with RR and IG3 embedding... Pseudo Nim Road Runner 12 08-19-2007 01:43 PM
Embedding IGuidance 3 into RR Bama5150 Road Runner 4 01-23-2007 07:40 PM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 01:46 AM
embedding iguidance in RR vfinterceptor SkinBedder 7 04-25-2006 02:41 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
