Old 03-07-2007, 12:30 AM   #1
GooPs 1.9.4 Released - Cursor Size, PointMarker, AutoView Rotate, bug fixes
GooPs version 1.9.4 Release Notes
New Adjustable Cursor Size.
3D cursor size can now be adjusted to your preference.
Selectable AutoView Rotate perspective.
The view perspective to the cursor can now be fixed at any angle (instead of just rear).
"Free" mode allows you to set the perspective to any angle via the Google Earth navigation controls.
New PointMarker feature draws a circle of a specific radius on the ground at every point
on the track.
This can be useful for applications where coverage of a specific area/width needs to be recorded and
analyzed (e.g. field coverage or search and rescue). This feature can be very resource intensive.
Track Point compression is now selectable.
Up until now, GooPs has always compressed track points (thrown away redundant
points). GooPs now gives you the ability to keep all track points
received from the GPS (It may be helpful to turn off compression when using PointMarkers).
RotateMinimum works again.
Baud Rate can now be set to 1200
Fixed problem with FTP client filename
This was broken if the file had no directory path. It now works with no directory path.
davidhite is offline   Reply With Quote
Bug Tracking (sorry long but please read) liquid_smoke Software & Software Development 23 04-22-2005 03:12 PM
