Old 03-08-2007, 12:39 AM   #1
jkiang is an unknown quantity at this point
BU-353 sucks?
So I recently bought a new BU-353 to replace my DeLorm Earthmate USB. The DeLorm one was very good once it gets satalites, but it takes like half an hour if I'm lucky to get any at all.
So after I receive the Bu-353, I installed it on my CarPC. OMFG sat. pickup was super fast. From cold start I picked up 8 sats in my garage in like 20 seconds. Sweet, so go for a drive. Jesus I started moving out of my garage, out of my drive way. IGuidance shows speed = 0mph and position stayed in my garage. WTF? So I stopped and check, and suddenly it caught up, and got ahead.
Then I kept driving, it just keeps trailing me about one block behind, and the speed update is bad. For example I hard accelerate from 20 --> 60mph, iGuidance shows about 20 for more than 5 seconds, then slowly picks up to 60mph.
I also realized that when I stop, the heading tends to spin around, making iGuidance tell me to make a uturn all the time.
Does anyone have the same problem, or did I just get a bad unit?
jkiang is offline   Reply With Quote
Old 03-08-2007, 12:57 AM   #2
NiSlo's Avatar
NiSlo is an unknown quantity at this point
Try using the GPSinfo application that comes with the receiver.
That gives you a speed and co-ordinates etc. See if that updates ok. If it does, then perhaps you might need to do some tweaking in IG. If not, then perhaps some settings on your pc may need some adjustment.
Doing this will help to narrow down the possibilities of where the problem is. From there it may become clear what you need to do.
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 03-08-2007, 01:11 AM   #3
GPSinfo also shows undesirale data. Like direction is all over the place when stationary, velocity was showing the speed 5 seconds ago. Good satalite counts though, which doesn't mean anything if it's not accurate.
Old 03-08-2007, 01:51 AM   #4
NiSlo's Avatar
What baud rate do you have it set to. 4800 is optimal I beleive
Have you tried changing switching ports?
Old 03-08-2007, 02:08 AM   #5
seanz0rz's Avatar
seanz0rz is on a distinguished road
mine has been going for a year and a half flawlessly, best piece of hardware ive ever owned.
you need to figure out whats happening on your computer, something is bogging it down.
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline   Reply With Quote
Old 03-08-2007, 02:58 AM   #6
The baud rate is set to 4800 in iGuidance, GPSinfo, and even the windows hardware property.
I also pluged the 353 into my laptop, and results are the same.
Do you guys have any idea what went wrong? Maybe I'll try to mess with SiRFtest a bit to see the settings in the BU353 itself.
Thank you anyways for your prompt reply though.
Old 03-08-2007, 03:47 AM   #7
Nomader's Avatar
Nomader is on a distinguished road
mine also works nice.. no problems at all.. my advice try to put it out of the car and check that.. or maybe it is a faulty unit..
Nomader is offline   Reply With Quote
Old 03-08-2007, 08:39 AM   #8
Mr_Civic's Avatar
Mr_Civic is an unknown quantity at this point
Try reinstalling the drivers as well and xPort if your using it; I had this issue and the reinstall cleared it up.
Alex
Progress: 91% (Cosmetics) @ Stand Still...
CarPC specs are BACK!! Edit yours today...
Mr_Civic is offline   Reply With Quote
Old 03-09-2007, 10:20 PM   #9
I kinda fixed it. I changed the baud rate of the GPS in SiRFdemo to 9600, and it lags a lot less.
Old 03-18-2007, 09:11 AM   #10
Kurack is an unknown quantity at this point
Just got my BU-353 and worked perfect out of box...Installed driver, util program picked it up at COM8 , configured iGuidance for COM8, very accurate. Running at 4800bps
Kurack is offline   Reply With Quote
Old 03-18-2007, 09:40 AM   #11
swift_gti is an unknown quantity at this point
Where do you have the unit positioned ?
I know that heated vehicle windows etc can sometimes screw with te signal.
swift_gti is offline   Reply With Quote
good place for web hosting and domain name? scott_fx Off Topic 14 10-25-2006 01:35 AM
Bu 353 sebberry GPS 1 09-04-2006 10:35 PM
FS : globalsat BU 353 gps receiver, brand new skuller Classified Archive 12 08-02-2006 10:20 AM
WTB: BU 353 GPS receiver penny1jordan23 Classified Archive 0 07-06-2006 09:52 PM
Can't get the BU 353 to work with Destinator plugin inniss777 Centrafuse 2 11-24-2005 03:56 PM
