Old 03-26-2007, 03:59 PM   #1
mm_202's Avatar
Map / POI data
Does anyone out there have/know of a POI database?
And a map database would be nice, too.
And if its a MySQL db, that would be amazing.
Thanks,
MM.
mm_202 is offline   Reply With Quote
Old 03-30-2007, 07:18 PM   #2
mm_202's Avatar
Unhappy No One??
No one other there can help me?
Is this something that other people are interested in, or am I the only one??
Old 04-01-2007, 04:49 AM   #3
rburhum's Avatar
Navteq has some POI great data in shapefile format, however, extremely expensive. There are some shady places online where you can find them.
rburhum is offline   Reply With Quote
Old 04-01-2007, 03:41 PM   #4
mm_202's Avatar
Thanks rburhum, I'll check it out.
Old 04-04-2007, 03:16 PM   #5
I found a forum with lots of info about adding POI's and such:
http://www.pocketgpsworld.com/module...iewforum&f=130
I'm looking for something for iGuidance but haven't had any luck really. It seems kind of limited with adding custom/your own POI's.
brendonius is offline   Reply With Quote
Old 04-04-2007, 08:44 PM   #6
quick thoughts:
http://www.ogleearth.com/links.html
http://www.poi-factory.com/
http://www.geonames.org/
devious is offline   Reply With Quote
Old 04-10-2007, 07:32 PM   #7
rburhum's Avatar
Thinking about it some more, I guess you could easily extract POI from MapPoint using their object model. However, I don't know if that violates the EUA so you should probably check that out (if you care that is )
Editing map data? bash1979 StreetDeck 1 05-30-2006 11:07 PM
2006 map data upgrade geekinsc StreetDeck 5 05-30-2006 08:57 PM
D3 POI is well $uck MatrixPC Map Monkey 0 01-14-2005 03:46 PM
Allbrite and controller work with RCA but not VGA alti LCD/Display 22 01-05-2005 01:47 PM
