The MP3car.com Store
Thread Tools Display Modes
Old 01-09-2008, 03:09 AM   #16
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
It seems to always be a problem and one so simple that you have to assume the nav developers never hibernate/standby. The driver developers don't either.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Sponsored Links
Old 01-09-2008, 02:16 PM   #17
tbird2340's CarPC Specs
tbird2340's Avatar
Vehicle: 2005 Dodge Ram Quad Cab
My Photos: (0)
Downloaded the new version C and I will try this afternoon.
Thanks!
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 01-09-2008, 06:57 PM   #18
tbird2340's Avatar
My Photos: (0)
So far that new .exe has worked 2 out of 2 times!
Old 01-09-2008, 10:11 PM   #19
Curiosity's Avatar
My Photos: (3)
Ah interesting! Thanks for reporting back. I guess this will be the new version but it's holding an extra few seconds worth of data which may explain the troubles reported when switching to iG4. It has to be lagging behind at least 1 or 2 seconds.
Old 01-10-2008, 07:54 AM   #20
tbird2340's Avatar
My Photos: (0)
This morning (coming out of hibernation) Xport never received any data from the GPS.. I closed out of Xport and went back in and same results.. I'm not sure if that is related to Xport or not but figured I'd let you know.
Sponsored Links
Old 01-10-2008, 03:18 PM   #21
tbird2340's Avatar
My Photos: (0)
Another update.. Today I have been 0/3.. At lunch it showed the GPS getting data and both ports 5 & 6 connected but in RR it didn't show the GPS connected and in IG it had 0/12 sats and all red (showing no connection).
Old 01-10-2008, 04:06 PM   #22
My Photos: (0)
Quote: Originally Posted by htsource View Post
I found this process.exe file:
Command Line Process Viewer/Killer/Suspender for Windows NT/2000/XP
Seems to work except I when I put this in a batch file for HibernateTrigger.exe, it starts iGuidance and the DOS prompt stays until iGuidance shuts down, then the DOS window disappear.
It doesn't seem to bother me as I run iGuidance in full screen mode anyway, but still it would be nice to get rid of the DOS window once iGuidance starts.
So far I've tried hibernating the tablet for about 10 times and it works every single time by starting iGuidance after hibernation.
Thanks guys.
You don't need a program to do that just open notepad and enter the following
Code:
TASKKILL /F /IM "iguidance.exe"
then save it as a .bat file. This also should close automatically after running instead of staying open.
Ryan711 is offline   Reply With Quote
Old 01-10-2008, 07:26 PM   #23
Curiosity's Avatar
My Photos: (3)
Well, I'm stumped. I drove around today and hibernated about 10 times. iGuidance 4 starts moving after maybe 3 or 4 seconds. My other 3 apps running work the same. There's something different. I just know what.
Old 01-11-2008, 08:14 AM   #24
tbird2340's Avatar
My Photos: (0)
Well it was 1/4 yesterday.. Ride home it worked! ARGH!! Should I try to somehow disable / enable my GPS/Comport when coming out of Hib?
Old 01-11-2008, 03:51 PM   #25
Curiosity's Avatar
My Photos: (3)
No. The GPS to XPort part is working. For you, the XPort virtual ports aren't hibernation friendly.
Some have better luck with GpsGate. So that's another option.
Old 01-14-2008, 10:28 AM   #26
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
I'm doing that with Devcon and Hibernate Trigger.
Check out this thread:http://www.mp3car.com/vbulletin/faq-...de-devcon.html
Machinehead is offline   Reply With Quote
Old 01-15-2008, 10:56 AM   #27
tbird2340's Avatar
My Photos: (0)
Are you having any of the issues I've described?
Old Yesterday, 12:20 PM   #28
Jfive96's Avatar
Vehicle: `96/Integra(sold)*`05/Durango(Gone)*`98/528i*`06/Commander
My Photos: (0)
- -I am having the same issues with Xport,IG4 and resume after hibernation. Are there any settings that are standard for Xport that someone can post that work??- -
Connections Etc.
*J.Crawford*
Tires, Rims, Auto Parts & Service and EVERYTHING in between!!!
Call : 214-552-6651 or email westway11@hotmail.com for all orders and any additional information.
Jfive96 is offline   Reply With Quote
Old Yesterday, 08:11 PM   #29
Curiosity's Avatar
My Photos: (3)
When you have trouble like that, it's usually something with the USB. Like you have it in a hub along with something else that's making it less reliable.
Old Yesterday, 11:53 PM   #30
Jfive96's Avatar
My Photos: (0)
- -Fixed!!!- -
- -My BU-353 is connected directly to the motherboard USB (no hub). http://www.mp3car.com/vbulletin/gps/...esume-fix.html , since the change It has worked flawless....- -
Connections Etc.
*J.Crawford*
Sponsored Links
vB code is On
Trackbacks are Off
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 55 06-08-2008 08:54 PM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 11:49 AM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
GPS Hibernation resume BOND007BE GPS 4 09-30-2004 03:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
