Problem making GPSSecure work with FreeDrive
I have tried all that I can think of, and I am still unable to get GPSSecure to work with FreeDrive. It works fine for me with MapMonkey.
I have read the Documentation and set my settings in GPS Secure to use FreeDrive.
It tells me on my Laptop and in my Car system that it is Connected/Not Running in Red.
Here is the Information from my config.xml file:
<?xml version="1.0" encoding="utf-16"?>
<Session xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" comPort="COM3" baudRate="4800" serverIP="67.182.214.7" port="5550" loggingID="xxxxxxxxxx" loggingPass="xxxxxxxxxx" logging="true" loggingFreqMin="0" loggingFreqSec="15" serverFreqMin="10" serverFreqSec="0" serverLog="true" SMTPLog="false" SMTPMin="5" loggingLive="true" liveRefreshRate="10" SMTPServer="" SMTPTo="" SMTPFrom="" Terra="true" MapQuest="false" connectGPS="false" connectMMonkey="false" connectFreeDrive="true" autoConnect="true" passwordPrompt="false" windowsStart="false" startMinimized="true" DUNEnabled="false" DUNName="" autoUpdate="false" skinNight="0" skinDay="0" MiniStatusBar="false" MiniDraggable="false" MiniX="0" MiniY="0" MiniOpacity="0" MiniSizeX="52" MiniSizeY="20" />
Here is the Changes that I have made to my FreeDrive SDK.ini file, so that you can see if this is the problem.
FDSPEED=RoadRunner,GPSSecure
FDSATS=RoadRunner
FDETA=RoadRunner
FDETR=RoadRunner
FDHEAD=GPSSecure
FDROAD=RoadRunner
FDLONG=GPSSecure
FDLAT=GPSSecure
FDALT=GPSSecure
FDTIME=
FDDATE=
FDEND=
FDDIST=RoadRunner
FDUNITS=GPSSecure
FDMAN=RoadRunner
FDNEXTMAN=RoadRunner
FDNEXTSTREET=RoadRunner
FDNEXTMANDIST=RoadRunner
FDMANFULL=RoadRunner
FDCAMS=
Hope that you can help me get this running.
Thanks,
Bryan
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
