Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 04-13-2007, 01:38 PM   #1
Lightbulb 4GB USB stick vs 4GB compact flash as bootup device?
Hey guys. I've been following the CarPC scene for quite a while (5+ years)...
I've gone through several different "revisions" of my project, but have never built a final product.. lol..
The last time I pulled the project out of the closet and dusted it off to tinker with, I followed a thread on how to boot off of an extreme III compact flash card -- and got all the hardware and everything.
Nowadays, USB thumb drives are getting cheaper and cheaper. I recently found a 4GB USB stick for about $25...
So now I'm curious. What are the pros and cons of booting off a USB drive?
I know the compact flash card has a limited write life, and you have to extensive software modification (EWF, HORM, etc) to make it work reliably. This is pretty much where I get stuck last time, and put the project back in the closet.
Are USB drives any slower or faster than an extreme III compact flash card? Do they have a limited write life? Are they reliable?
Thanks for all the info!
mattress is offline   Reply With Quote
Advertisement Sponsored links
Old 04-13-2007, 05:28 PM   #2
SFiorito's Avatar
All flash has limited write cycles, so you'll need EWF on the USB stick as well. If you get the right USB stick it can be much faster than a typical consumer level CF card. SanDisk has much faster CF cards out now though.
The only problem with USB is that you need the right mobo (BIOS needs to support hi-speed USB booting), and the configuration isn't as simple as CF. Search the forums I've got some posts on USB booting. I've done it before with M-System's uDOC which was very fast and easy to set up because they have software support for it and I did it on a consumer high speed thumb drive.
SFiorito is offline   Reply With Quote
Old 04-14-2007, 12:31 PM   #3
I'd recommend doing some research. I know for a fact that Sandisk has some of the fastest CF cards available (their extreme IV series, I believe). You'll defintely pay more than $25 for it but I'm fairly certain that at memory stick like that is gonna be limited to about 8-10mb/s
ak47clown is offline   Reply With Quote
USB IR stick to COM port?? vxcarpc Input Devices 17 03-20-2008 07:31 PM
" HI-SPEED USB device is plugged into a non-HI-SPEED USB hub" Error - HELP!!! hd54321 General Hardware Discussion 15 05-04-2006 05:53 PM
Can a GPS antenea be recognized as a Serial and a USB device? Skipjacks GPS 6 01-21-2005 03:12 PM
lilliput won't work - USB device not recognized... aegray Input Devices 15 09-27-2004 11:49 PM
Booting with USB memory stick Fluffy General MP3Car Discussion 12 10-01-2003 06:47 PM
