Hello,
sorry for being absent for while and not reading here...
I noticed this thread just before the question to buy Smarttire sensors again or to change the system to a cheaper one. So I decided to change (my summer-tires also need new sensors...)...
I choose the Waeco TPMS (
www.waeco.com) stuff for only 100 Euro and with 4 sensors but without a display (which I, and I guess you guys too, don't need) and it would be good to have a system from a vendor "with a name" (in 5-6 years if you need new sensors - but the batteries could be exchanged easily).
Quote: Originally Posted by
Robby BMW
Discovered this, I’ve noticed that the whole data packet consist of 14 bytes (112 bits) organized in this way:
Preamble (32 bits) - The preamble is a series of 31 logic ‘1’ bits followed by a single logic ‘0’ bit (FFFE in hexadecimal), used to recognize the RF transmission as a valid TX message.
no
... the Preamble is 16 bits (FFFE) (your digitrace screenshots also shows only 15 bits at 1)...
The Waeco system also transmits on 433Mhz AM with a differential manchester coding... which looks like (!) that:
which gives for example a: FFFE 001C40F7 81 30 DA 01 E258
with Robby's findings these can be interpreted to a tire pressure of 2,2bar (I have a normal car!) and 8°C (which perfectly fits into a german winter) and 218 of 255 (new sensors with new batteries!) (How does the CRC fit inside ? I didn't get it to work...)
So I guess the Waeco system is compatible ?
This all sounds too good ? Then have a look at the PCB of the receiver
The receiver is this shielded box connected with 7 pins to the main pcb... it gets 5V+ , ANT (external antenna!) and GND and devlievers the signal and the field strength...
easy to desolder ?
no saw needed.. only a soldering iron...
I guess Robby has to send me that PIC quickly
(PayPal!)...
Cheers to Robby !
