01-31-2008, 03:55 PM
#271
Quote: Originally Posted by juve021
Wait so Robby, can I use this to test my receiver if I DO NOT have the sensors installed in my wheels?
it probably depends on your kit. I'm working on an install and my sensors don't seem to activate unless they see some differential pressure. I.e. even using the original interface, the sensors flash not found until there is some pressure difference to activate them. This could just be the way my sensors were designed however, and yours may work differently.
01-31-2008, 05:06 PM
#272
@ Almera: Oh, no worries - hope it works for you, sometimes the sensors needs some pressure change over a specific period of time before they will activate and send readings, otherwise they might do so when you go over a bumpy road, for example, which can/will give false readings if the sensors are not filtering these "spikes"
Let us know how you go.
@ Robby: Looking very good, I will test it when I get home the afternoon, just started the day at work Down Under - and I was pleasantly surprised to see the software ready when I loggen on
Thanx again for your efforts, it is appreciated!
02-01-2008, 11:28 AM
#273
You can test your receiver with this program outside RoadRunner, but remember that to "wake" the sensors, the pressure needs to be increased above 1.5 bars.
Basically the sensors operate in 5 different ways depending on the situation:
1. Storage mode: If the pressure is below 1.5 bar, pressure is measured every 60 seconds but no data is sent. If the pressure increases above 1.5 bars, the sensor shifts into the Initial mode.
2. Initial mode: This mode occurs if the pressure increases above 1.5 bar from Storage mode. In this mode, pressure is measured every 0.85 seconds and data is sent every 0.85 seconds. This sequence is repeated 256 times. After the sequence is repeated 256 times, the sensor shifts into the Normal mode only if pressure is above 1.5 bar. If the pressure is below 1.5 bar, the sensor will shift into the Storage mode.
3. Normal mode: Pressure is measured every 3.4 seconds and data is transmitted every 60 seconds. If the measured pressure differs by more than 200 mbar from the reference taken every 60 seconds, the sensor enters a Pressure Alert mode.
4. Pressure Alert mode: It is the same measurement and transmitting pattern as the Initial mode.
5. High Temp Alert mode: If the temperature exceeds 120°C, the sensor device enters into the same measurement and transmitting pattern as the Initial mode.
_______________________________________
Car installation 95% [ ■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
02-01-2008, 11:54 AM
#274
I'm running my car off-road, and depending on the terrain/surface, I run on tire pressures well below 1.5 bar.
Do you guys know if the threshold for the different modes can be adjusted?
Petter
02-01-2008, 11:55 AM
#275
Has anyone tried Robby's pic setup with the Hella TPMS yet?
02-01-2008, 02:38 PM
#276
Played around with the air in my tyres but the config tools doesn't want to abort its Learn procedure... I don't know whats going on because the new tool also doesn't change any values. I only have this screenshot.
I would like to read my ID 001C40F7 sensor somewhere...
02-01-2008, 04:19 PM
#277
@ Petter: You can adjust the upper/lower limits at which the alarms will activate.
@ Fmode: Are you running the config tool in windows, and not having RoadRunner installed? If that's the case, it won't abort the learn - you must have Roadrunner up and running, before you can run config tool - in the above screenshot, with the test-routine, it seems all is well with your setup.
 Is your 5th sensor installed in the spare tyre, or not?
Anyway, for those unsure how to do their own conversion kit, look at page 9 in my Project Log, I made a nice how-to, with plenty pics, on how to marry the 3rd EYE TPMS to Robby's USB interface board.
Post questions there if you have any.
02-02-2008, 06:14 AM
#278
Your screenshot shows that everything is working well, the only strange thing I can see is a discrepancy between the pressure detected by the sensor number 1 and the related raw data, but it may be a bug in the program and not a problem with your setup, I have to check this.
The reason because the config tools doesn't want to terminates the learning procedure is because the system will not save any identical sensor ID, and since all your sensors are been succesful paired the first time, if you try to start the learning procedure again, the device will be waiting for a new sensor with an new ID other than the ones already stored in the PIC (this is the case when a sensor needs to be replaced with a new one).
Another important thing, unlike what most people think, is that the config tool can be used also without having RoadRunner installed.
Indeed the program is basically divided into two parts, the first is for setup the parameters in the ini file handled by the RoadRunner plugin (measurement units, warning thresholds, etc), and the second is for "the learning procedure" that is completly handled by the firmware on PIC, regardless of the software used to display the data.
Finally, the sensor IDs are stored in the E2PROM of the PIC for internal use, and there is no way to read them through the USB port, at least without make some change in the firmware, but this is not essential for the normal use of the device.
02-02-2008, 04:28 PM
#279
That clears a few things up, thanx Robby
So we can actually use the config without RR, which is what I first tried, but it did not do anything for me - only after having RR installed, and the app running, could config tool stop flashing abort sequence....
But, probably 99% something I have done wrong with the pairing process then, will check it out and feedback.
Thanx.
02-02-2008, 05:12 PM
#280
Sorry to potentially beat a dead horse here, but, I do not use road runner at all. By what you say above, it seems you need to do the config in roadrunner, but can then run the app w/out road runner. Are there options for those that don't use RR at all? Could I just manually edit the ini file, and then use your app (what the screenshots have been of) for monitoring?
TIA,
Per
02-03-2008, 01:34 AM
#281
@ Per: Look at Robby's post 268 on the previous page, he posted a link to a standalone test program there, which is the same as the screenshot you see above from Fmod - it is a different application to the config for Roadrunner.
02-03-2008, 09:01 AM
#282
2. testrun now on the street while driving for 10 minutes but no changing of any values...
(with your PIC in an experimental stick-board and connected to the WAECO receiver just lying freely in my trunk)
Where do those values come from which are displayed - they appear if I connect the PIC thats for sure ! Are these values from the EPROM ? Did you earase my EPROM before you send me the PIC ?
Its not really necessary for me to get this running (WAECO) with your PIC but I think the forum is interested...
02-03-2008, 11:19 AM
#283
Thanx.
Probably it was only a coincidence, moreover the configuration tools should be always used with roadrunner closed in order to prevent conflicts between the two programs and the USB comunication.
However, at the end are you were able to pair the sensors?
02-03-2008, 11:30 AM
#284
Thanks much
02-03-2008, 12:11 PM
#285
Those values are the last data received from the sensors, and they come from the internal E2PROM of the PIC.
After programming the PIC, I make a small test to be sure that it works as expected, but before to ship it, I erase always the data stored during the test in the internal E2PROM.
However you can try to erase again all the data stored in the PIC yourself and then perform again the learning procedure.
This is the procedure:
Connect the PIC to an USB port of your PC and start the new program (TPMS Doctor).
Press and hold on the shift button on your keyboard then clik on my avatar in the bottom left hand side of the window, two new buttons will appear.
The firs button (Master Reset) completely erase all data stored in the PIC memory (sensor IDs and data received), the second one (Data Reset) erase only the data received (pressure, temperature, etc) but not the learned sensor IDs.
| Thread Tools |
| Display Modes |
Linear Mode
