Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 05-12-2008, 08:20 PM   #511
Raw Wave
HiJackZX1's Avatar
Quote: Originally Posted by rgarjr View Post
Yeah JP3 is your ground and there's 2 pins. Which method are you gonna use, cutting the receiver part or pin method
I have cut the board in half.... i couldnt deal with having to run more electrical wires.... So technically jumper 3 isnt really 2 pins, just a ground split into two. Im concerned about jumper 1 though.... there is a small diode or what ever you call it. It says 002 on the diode..... Do I pull this off then soder jumper 1 to both to make it one?
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [50%]
BUG WORKOUT [90%]
INTERIOR MODS [75%]
BUDGET [380%]
HiJackZX1 Work Log
DodgeTalk
HiJackZX1 is offline   Reply With Quote
Old 05-12-2008, 08:41 PM   #512
rgarjr's Avatar
MrBean was kind enough to snap some close up shots of the board
pic
I think you're talking about that small resistor on there. Yeah just leave that little guy there and solder your pin to the pad of it, nearest the cut.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 05-12-2008, 10:49 PM   #513
Quote: Originally Posted by HiJackZX1 View Post
PS: Thanks LYHTSPD, I got the 3rd eye kit in the mail today!!!!!!!!!!
Nice!
LYHTSPD is offline   Reply With Quote
Old 05-12-2008, 11:58 PM   #514
I know this is maybe a dumb question, but on the board is jumper 3 supposed to be together? Like soder wise? I noticed in Robby's picture of the board its together.... and the one I recieved from Jueve is also together...... Is this correct? Also what is the easiest way to sepearte what I need from the third eye kit? Aslo when sodering jumper 1, do I have to remove that tiny diode or soder with it on there?
I wondered the same thing...when I tested it with a meter, it was showing continuity, which concerned me a little! But after looking at the schematic, all was well...
WuNgUn is offline   Reply With Quote
Old 05-13-2008, 02:15 AM   #515
Robby BMW's Avatar
JP3 is double to ensure a better mechanical fastening.
You can remove the small resistor and solder JP1 on both pads like in the picture below:
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 05-13-2008, 05:07 AM   #516
lez
lez's Avatar
soder
grrrrrrrrrrrr
wiki is your friend, it's got an L in it, pronounced SOLD - ER
I blame Norm and his New Yankee workshop for this, I've heard him soddering so many times.............
Lez.
XM 2.1TD ~ Morette triple headlights+HID ~ Leather kit ~ XC70 alloys
Exhaust rear boxes removed ~ meshed air filter
lez is offline   Reply With Quote
Old 05-13-2008, 06:38 AM   #517
Raw Wave
HiJackZX1's Avatar
*slaps LEZ in the back of the head* This isnt english class..... I spelled it the way I say it, lol......
Anyways, did I have to put the pins through the holes? I really wasnt able to get them through so I simply soldered (are you happy LEZ) them to the board without sticking through the holes. Jumper 1 I soldered to the end of the pad with the resistor, I was really scared of damaging the board. Jumper 2, I simply scrapped the green top layer off then soldered to the copper (was this right). When I insalled it into the PC it said, "New Human Interface Device Installed". So I guess I did it correctly, or will it install even if I did it wrong?
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [50%]
BUG WORKOUT [90%]
INTERIOR MODS [75%]
BUDGET [380%]
HiJackZX1 Work Log
DodgeTalk
Old 05-13-2008, 06:53 AM   #518
Confusion Master
Enforcer's Avatar
Gay?
Enforcer is offline   Reply With Quote
Old 05-13-2008, 08:11 AM   #519
Robby BMW's Avatar
http://www.urbandictionary.com/defin...term=Soddering
Old 05-13-2008, 08:14 AM   #520
I had a hard time getting the J3 header pins through the holes, but eventually I got them through. As long as there are making an electrical connection you should be ok. It may not be as physically strong connection though. I would keep an eye on it and expect to re-solder it at some point.
What you did with J2 is fine. That is really the only way you can make that connection. I left the resistor on J1 as well on my boards.
Old 05-13-2008, 08:39 AM   #521
Robby BMW's Avatar
Inserting the JP3 header pins through the holes ensures better mechanical fastening, but the important thing is to guarantee a good electrical connection.
To connect JP1, the small resistor can be removed or not, it is irrelevant to the proper functioning of the device.
The only way to connect is to JP2 is to scrape a small part of the green top layer (solder mask) off then soldered the header pin on the copper
Old 05-13-2008, 08:48 AM   #522
Robby BMW's Avatar
It only means that the USB interface (the PIC) is working.
The only way to know if also the receiver is working is to plug an oscilloscope probe to JP2 in order to see if some signal is incoming or, more simply, perform the learnig procedure as largely described in this thread.
Old 05-13-2008, 09:05 AM   #523
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by Robby BMW View Post
sod·ding. Chiefly British Slang.
–noun 1.sodomite; homosexual.
Old 05-13-2008, 11:57 AM   #524
lez
lez's Avatar
Quote: Originally Posted by Enforcer View Post
Gay?
Have you seen the shirts he wears, and he's wonderful with his hands...........
Lez.
Old 05-13-2008, 04:26 PM   #525
Raw Wave
HiJackZX1's Avatar
Who are we talking about, Im lost..... I was gonna say how do you know about my shirts LEZ!?!?!?!?!
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [50%]
BUG WORKOUT [90%]
INTERIOR MODS [75%]
BUDGET [380%]
HiJackZX1 Work Log
DodgeTalk
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 101 11-11-2008 08:33 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
