Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 06-23-2008, 05:58 PM   #556
_Dejan_'s Avatar
Quote: Originally Posted by Lok View Post
You should have the paypal payment dejan...
Yes and you have mail
_Dejan_ is offline   Reply With Quote
Old 06-23-2008, 05:59 PM   #557
Lok
Lok's Avatar
The retailer I just bought my 3rd eye kit from sent me an email saying that they are out of stock and have it on back order for 3 weeks. Is there anywhere else I can buy it from? (vivaperformance is out of stock as well...)
Lok is offline   Reply With Quote
Old 06-23-2008, 06:05 PM   #558
I just sent a payment for the last one!! *phew* almost missed it!
steven765 is offline   Reply With Quote
Old 06-23-2008, 10:25 PM   #559
Lok
Lok's Avatar
where did you get your 3rd eye kit? I am having difficulty finding one in stock...
Old 06-23-2008, 10:30 PM   #560
Raw Wave
HiJackZX1's Avatar
Try messaging LYHTSPD. Maybe he has some left over.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [50%]
BUG WORKOUT [90%]
INTERIOR MODS [75%]
BUDGET [380%]
HiJackZX1 Work Log
DodgeTalk
HiJackZX1 is offline   Reply With Quote
Old 06-24-2008, 08:25 AM   #561
I do not have any of the 3rd Eye kits left, but I do have several of the USB converters left. They are complete with Robby's PIC, case, and USB cable. PM me if you are interested.
LYHTSPD is offline   Reply With Quote
Old 06-24-2008, 10:47 AM   #562
Lok
Lok's Avatar
For those of you guys that have the 3rd eye system and have hacked it apart I have some questions. I have been looking at as many pictures as I can of the actual internal reciever PCB board. From what I see its just 1 IC (TDA5200) which sells for about $4, a RF reciever (looks like a spring), a crystal or two, and a few resistors and caps. I have the means to solder surface mount components using my SMT line...I think we may be able to produce this board for under $40 and then simply have to buy the sensors from viva ($99). My main concern is programmed ICs, from the pictures I don't see that the reciever has any but of course Bobby's PIC is programmed but other than that I don't see any other hurdles...Are there any components I am missing? Also I am interested to know how the sensors are paired to reciever I would think that there should be some programming in there as each sensor has its own ID number which would need to matched but maybe its something standard that can be done just by the front end???
Old 06-24-2008, 10:53 AM   #563
Confusion Master
Enforcer's Avatar
Try contacting Enak.
Although he's in the UK so shipping might make it expensive.
Enforcer is offline   Reply With Quote
Old 06-24-2008, 12:04 PM   #564
_Dejan_'s Avatar
Lok & steven765 boards are on way
I think I have material for one maybe two boards and if I have it I will put it on ebay
Old 06-26-2008, 01:19 PM   #565
_Dejan_'s Avatar
I have only one kit(board, PIC, case) left... If there is some interest to get it then contact me by PM...
Old 06-28-2008, 08:59 AM   #566
I just received Pic chip and install on my deceive and plug into usb port.
nothing happend.
Captain Nguyen is offline   Reply With Quote
Old 06-28-2008, 11:01 AM   #567
nothing happend.
This is probably a silly question, but which way did you put the pic into the socket? The small embossed semi-circle on the top of the chip is supposed to go toward the USB socket.
Also, make sure you check voltage across J1 and J3. You should have about 5v DC.
Old 06-28-2008, 12:27 PM   #568
_Dejan_'s Avatar
nothing happend.
You are do something wrong in your device... Do you see it in Device manager?
Old 06-29-2008, 09:20 AM   #569
No I did not see in Deceive Manager.
The pic is in the good way plugged into the socket.
Witch small circle toward usb socket.
And I read 5V dc.
I'm not sure, but must pic programmed first?
If yes, then is the pic not programmed.
Old 06-29-2008, 10:52 AM   #570
_Dejan_'s Avatar
And I read 5V dc.
If you are buy PIC from robby then is already programmed if you are not then you must buy it from him...
I can't help you a lot with your board... Do you have right PCB? Did you build it yourself?
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 101 11-11-2008 08:33 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
