Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 06-29-2008, 02:11 PM   #571
Quote: Originally Posted by _Dejan_ View Post
If you are buy PIC from robby then is already programmed if you are not then you must buy it from him...
I can't help you a lot with your board... Do you have right PCB? Did you build it yourself?
Aight then I must get one from Robby..
Board layout come from Robby and I create PCB meself.
Here is any pictures of my pcb.
No it's not soldermask, it's green coatng with flux.
[/quote]
Robby you have PM. (mail)
Captain Nguyen is offline   Reply With Quote
Old 06-29-2008, 02:17 PM   #572
_Dejan_'s Avatar
If you are not buy programmed PIC from Robby or. any other guy who sell boards and you are buy it on electronic store you can't do anything from this PIC because you don't have program...
_Dejan_ is offline   Reply With Quote
Old 06-29-2008, 02:23 PM   #573
Yes I get it.
I have already mailed to Robby.
Old 07-01-2008, 10:51 AM   #574
Quote: Originally Posted by FMode View Post
no ... the Preamble is 16 bits (FFFE) (your digitrace screenshots also shows only 15 bits at 1)...
The Waeco system also transmits on 433Mhz AM with a differential manchester coding... which looks like (!) that:
Attachment 46935
Hi FMode,
Could you please tell what the Receiver PIN connected to INPUT1? Is it "pin5 fieldstrength"?
a__l is offline   Reply With Quote
Old 07-03-2008, 06:16 PM   #575
Hello Robby BMW
Can tou please send me a Pic so i can make the PCB.
Thanks for all
Bruno Pereira
myrus is offline   Reply With Quote
Old 07-04-2008, 12:18 AM   #576
I have two USB interface boards (populated pcb, programmed PIC, enclosure, and 6ft USB cable) left. If you are interested in one, shoot me a PM.
LYHTSPD is offline   Reply With Quote
Old 07-04-2008, 09:21 AM   #577
Robby BMW's Avatar
Quote: Originally Posted by myrus View Post
Hello Robby BMW
Thanks for all
Bruno Pereira
I sent an e-mail the last week, have you not received my message?
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 07-05-2008, 02:03 PM   #578
Can anyone take some high res photos of both sides of the cut section of the 3rd Eye board? I don't have anywhere near the money to buy one just to cut it up, but am good at soldering SMT.
300SD81 is offline   Reply With Quote
Old 07-07-2008, 04:47 PM   #579
Raw Wave
HiJackZX1's Avatar
I am so bad at sodering, but it is a very easy mod. I did it in about 30 minutes (took me awhile because i didnt want to mess up and flush $140.00 down the toilet.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [50%]
BUG WORKOUT [90%]
INTERIOR MODS [75%]
BUDGET [380%]
HiJackZX1 Work Log
DodgeTalk
HiJackZX1 is offline   Reply With Quote
Old 07-07-2008, 04:56 PM   #580
rgarjr's Avatar
Carefully cutting up the board with a dremel is the fun part. You also need to separate the 2 boards by unsoldering like 6 pins, or you can just dremel the pins out.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 07-08-2008, 12:42 AM   #581
I was thinking of just buying the sensors, obtaining the chips from the board myself, and making one.
Old 07-09-2008, 01:09 AM   #582
rgarjr's Avatar
Do you guys think where u mount your receiver/pic board matters on the car? I noticed that my rear wheels read 30PSI when I know there's like 45PSI on them. The front wheels are measuring fine.
My carpc worklog
Old 07-09-2008, 02:05 AM   #583
GizmoQ's Avatar
I'll take one. Respond to my PM with terms.
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Old 07-09-2008, 02:30 AM   #584
Robby BMW's Avatar
It is due to a bad signal reception from the rear tire sensors, as the system stores the latest data received, if it is unable to receive fresh data, it will display the latest values received.
Try to place the receiver in a different location.
Old 07-09-2008, 04:04 AM   #585
So is anybody selling a complete kit for this? If so can someone point me in the right direction.
Thank you.
dacho is offline   Reply With Quote
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 101 11-11-2008 08:33 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
