Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 07-24-2008, 02:38 PM   #661
It's alive!!!
Thank you Robby BMW.
BTW sensors are sleeping mode. not builded in wheels just testing.
Captain Nguyen is offline   Reply With Quote
Old 07-24-2008, 05:35 PM   #662
wiggy's Avatar
Quote: Originally Posted by LYHTSPD View Post
Wiggy, I did test all of the usb interfaces before I sent them out. I made sure that all sensors could pair with the device, and then did a Master Reset to clear out the sensor ID (I was not sure which tire would end up where on the final installation).
I did see this happen every once in a while when pairing the sensors. I started to wonder if there was just too much RF traffic from all the sensors, and the receiver PIC could not handle all of it. At that point I would usually just call it a night and come back to it the next day, and it would not have any problems. *shrug*
Edit: From what mrBean said, was there any changes in the PIC code Robby?
Sorry ..i didn't mean it to sound that way (about testing the unit)...i do appriciate the hard work you did
I have been trying to get this to work for about 3 weeks now ...so i think its more of a problem than just letting rest for the night .
Im posting mine to Robby tommorow so he can check out the pic ..hopefully it will be something easy to rectify.
wiggy is offline   Reply With Quote
Old 07-25-2008, 08:43 AM   #663
Hey Robby,
Thanx for your efforts I am in not such a rush, I gave my unit to my friend, and I have the "faulty" one now, but I am sure it will be something small.
Keep us posted.
Kind regards,
Phillip
mrbean_phillip is offline   Reply With Quote
Old 07-25-2008, 09:14 AM   #664
Oh, don't worry. I was not offended by the comment. I just wanted to let you guys know that I did test them.
I am curious to find out what Robby finds.
LYHTSPD is offline   Reply With Quote
Old 07-25-2008, 11:46 AM   #665
hope the problem will be easy to solve...
but we are pretty sure it has something to do with the receiver and not the sensors right?
coz tuesday i will have my tires replaced, and get the sensors installed.
hope i will not have to deinstall and reinstall them
Greetz
Dj NRG
Dj-[NRG] is offline   Reply With Quote
Old 07-26-2008, 05:40 AM   #666
Robby BMW's Avatar
I don't think the problem is related to the sensors, but to be sure, I need to do a complete check to Wiggy's unit.
I will keep you informed about any progress.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 07-26-2008, 08:24 AM   #667
I'm having issues with my TPMS...
Whenever I resume the PC, Windows doesn't recognize the USB device. I have to unplug and plug it back in, then it's reinstalled.
And having it plugged in seems to kill my audio performance...like it's hogging the PCI bus or something. And this is with it not even reading the sensors!
WuNgUn is offline   Reply With Quote
Old 07-26-2008, 11:41 AM   #668
Confusion Master
Enforcer's Avatar
Sounds like a similar issue I am having with the PDC version, although it only seems to be on the car PC, it's fine on my laptop, and funnily enough fine on my backup CarPC which uses exactly the same MB.
It only seems to be the one I want to use it with. (also my Gyration Keyboard suffers from the same problem, but my mini USB keyboad doesn't )
Enforcer is online now   Reply With Quote
Old 07-28-2008, 02:38 AM   #669
That's my working version of TPMS plugin(WAECO) for CF.
(Car photo has been take from http://www.mp3car.com/vbulletin/rr-p...on-plugin.html if Robby BMW don't mind. Otherwise I will remove it. That's not for commercial purposes..... ).
a__l is offline   Reply With Quote
Old 07-28-2008, 06:57 AM   #670
Robby BMW's Avatar
How do you have connected the interface? Directly to an USB port or trough a HUB?
Old 07-28-2008, 06:58 AM   #671
Robby BMW's Avatar
Feel free to use any image
Old 07-30-2008, 08:12 PM   #672
The Standalone TPMS utility link does not work; Nor do the PCB links in post #1. Did the domain go down?
96300NAZ is offline   Reply With Quote
Old 08-04-2008, 08:59 AM   #673
goosey2099's Avatar
Any News on this??
4G64 5 SPEED
MY CAR - MY 5SPD - MY CARPUTER - MY GARAGE SALE
goosey2099 is offline   Reply With Quote
Old 08-04-2008, 10:10 AM   #674
I've tried both...with pretty much the same results.
With just the TPMS hooked up, and nothing else, it's okay, but the TPMS seems to load up the system someway when I connect my other USB devices.
But when I have ALL my USB devices mounted, but no TPMS, the system is also fine...
Old 08-04-2008, 10:20 AM   #675
hmm, is anyone else having this problem. I've been compiling the parts for my carpc build and i'll be using a lot of usb devices.
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 93 08-11-2008 09:40 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 03:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 03:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 10:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 09:52 AM
