08-04-2008, 12:53 PM
#676
Quote: Originally Posted by WuNgUn
I've tried both...with pretty much the same results.
With just the TPMS hooked up, and nothing else, it's okay, but the TPMS seems to load up the system someway when I connect my other USB devices.
But when I have ALL my USB devices mounted, but no TPMS, the system is also fine...
Maybe a powered HUB could solve your problem.
_______________________________________
Car installation 95% [ ■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
08-04-2008, 12:55 PM
#677
My 'hub' is powered off the PCI slot, since it's a PCI to USB adapter...
Same results with that hub, or the onboard USB ports...
08-04-2008, 12:56 PM
#678
Quote: Originally Posted by 96300NAZ
hmm, is anyone else having this problem. I've been compiling the parts for my carpc build and i'll be using a lot of usb devices.
I know one other person for sure, depending on which PC he uses it on...but he's having the same issues I think.
08-04-2008, 01:08 PM
#679
@ wiggy, goosey, Dj-[NRG], mrbean_phillip and all those who have problems performing the "learn" procedure, I've found an issue with the USB buffer that causes an abnormal termination of the procedure.
The problem has been fixed in the last releases (1.30) of my two programs TPMS Doctor and RRTMS, so please download them, upgrade your systems and let me know if this solve.
As usually, I recommend everyone to terminate all the programs that have direct access to the TPMS interface, like RoadRunner, Centrafuse and TPMS Doctor, before to launch RRTMS Config and to perform the "learnig" procedure.
08-04-2008, 01:10 PM
#680
Is there an updated Centrafuse plugin too?
08-04-2008, 01:18 PM
#681
As the Cetrafuse plugin has been developed by Wolfgang, I don't know if it has the same bug, but using the new version of my Config Tool, you should be able to perform the "learning" procedure without problems.
08-04-2008, 01:31 PM
#682
Im send to Wolfgang email with new source and tell him that some guys have problem in learning methode...
08-04-2008, 01:42 PM
#683
Thank you Dejan.
Please tell to him to feel free to contact me for any questions.
08-04-2008, 02:22 PM
#684
Thx Robby,
will try that as soon as possible.
I'll let you know if it works
Greetz
Dj NRG
08-04-2008, 06:07 PM
#685
Quote: Originally Posted by Enforcer
Sounds like a similar issue I am having with the PDC version, although it only seems to be on the car PC, it's fine on my laptop, and funnily enough fine on my backup CarPC which uses exactly the same MB.
It only seems to be the one I want to use it with. (also my Gyration Keyboard suffers from the same problem, but my mini USB keyboad doesn't  )
That doesn't sound good,are you still having the issue?
Robby's found issue with the tpms software,is it likely the same bug is affecting the pdc setup?
P4 2.8 HT, 1GB Ram, 200Gb 3.5 HD, M4-ATX,2 x Silabs USB, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RoadRunner, iGo8,Custom Freedom 2.1
08-04-2008, 06:15 PM
#686
Confusion Master
I doubt it, the PDC's actually work, it's just my board/software is struggling to hook up to the box.
Thing is, it's only the carputer PC, my laptop is fine, and another PC which has the same board as the carputer is fine, although it doesn't have exactly the same XP install. I need to get a 2.5" drive in there and ghost the carputer one, so I can do some parallel testing.
08-04-2008, 08:54 PM
#687
I'm having this problem, without even running the software...just having the thing plugged in does it...
08-05-2008, 08:24 AM
#688
I also am now having a similar problem with RR. It would appear that several tyres are picking up the same sender unit, as the Hex codes showing in the Doctor, are all the same.
I dont have to adjust the tyre pressures after resetting the doctor, as all I do is go into training mode, and the tyres just get configured.
08-05-2008, 11:52 AM
#689
This bug has been fixed, download the new releases of TPMS Doctor and RRTMS.
| Thread Tools |
| Display Modes |
Linear Mode
