I have just installed the 3'd eye sensors on my wheels.
Quality is not impressive. I manage to destroy one sensor.
The instruction manual was not specific on how to place washers. I did not use my sense, and placed alu washer on wrong side first as I tried to do it as I could see from picture in manual. Alu washer goes on the outside...
The aluminium nuts also loose shape once fitted, and it is a bit difficult to refit the tyres. At least the low profile 18" I've got on my E46 BMW.
The washer for the insex nut at the sensor also gets deform once mounted.
The pin for holding the pin still when fastening the nut did not fit 3 of the 5 sensors I tried.
In short, you get one chance to do it right and you cannot refit a sensor once used.
A bit disapointed of the poor quality and I have not yet got to the point of learning sensors and receiving data...
One question: Without looking into the spec of the pic the learning problem must be in the writing/erasing of EEProm/flash in the pic. Or possibly some powersupply issue as write cycles might require a second voltage supply. What do you think? Is there a new pic sw in the pipe?
