Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 11-08-2007, 04:37 PM   #121
Laptop, Tablets, UMPC Moderator
turbocad6's Avatar
awe man, I just ordered it seconds before you posted that!!!
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 11-08-2007, 08:14 PM   #122
Update:
Just received my 3rd eye TPMS from Viva. Its the same exact kit yay!
juve021 is offline   Reply With Quote
Old 11-09-2007, 01:22 AM   #123
Keep us posted on your efforts, guys
I am talking to a colleague of mine in Taiwan, he will hunt down a supplier of the same kit - I found one via my google searches, he will check pricing, and possibly find the supplier.
I will keep you posted on pricing and a possible contact.
Br,
MrBean
mrbean_phillip is offline   Reply With Quote
Old 11-09-2007, 01:45 AM   #124
Robby BMW's Avatar
Quote: Originally Posted by turbocad6 View Post
what I think would be sweet would be if you were able to do robbies interface & still have the display too, is this possible? tap into the data instead of diverting the data?
just curious, def not a deal breaker, but that would be cool to for some installs I think...
Yes, it's possible.
This afternoon I'll post a picture with the exact point where get the data out without opening the original TPMS display receiver.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 11-09-2007, 08:20 AM   #125
Robby BMW's Avatar
With the "3rd Eye TPMS" kit is provided a power cable that ends in a white connector with 3 wires (Red - +12V, Orange - Ignition key ACC and Blak - Ground)
On the connector there is also an empty hole where can be added a crimp terminal, on this pin is available the signal received from the tire sensors.
Old 11-09-2007, 11:03 AM   #126
So Robby, where would we hook up this pin on your interface to? I would assume one of the header pins on your interface board, but which one?
Old 11-09-2007, 12:04 PM   #127
_Dejan_'s Avatar
You must get data on JP2
_Dejan_ is offline   Reply With Quote
Old 11-10-2007, 04:02 AM   #128
Robby BMW's Avatar
You need to connect this pin to the JP2 and the pin with the black wire to JP3 throug a shielded cable.
Old 11-10-2007, 08:38 AM   #129
Wow, this is great! I might actually connect your interface this way so that I can salvage the control/lcd part of the TPMS (for another install on a later vehicle!). I really don't want the display to be seen so I'll just do a stealth install of it (maybe put it in the trunk next to my car pc!!)
P.S.
I've received the components for the interface Robby, almost ready to populate the board and give it a go!!
One thing, if I hook up the interface to the car pc with no sensors mounted, will the interface read 0 for all the values of each sensor?
Old 11-10-2007, 09:12 AM   #130
Robby BMW's Avatar
P.S.
No, it will be displayed -- for each values like when the interface is not connected to the PC.
Don't forget to do before the "learn" procedure as described in the config utility in order to get all your sensors paired with the interface.
Old 11-10-2007, 12:16 PM   #131
inh
Just ordered my PIC =]
It's going to be a looong time before I can do this, but I figured might as well get the parts now =]
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 11-10-2007, 01:53 PM   #132
Sal R.'s Avatar
Just ordered my TPMS kit.
Got a skin all made up.
Just need to get ahold of the USB interface board and I'm all set...
nLite'd XP Pro / RR v09/10/2008 / Winamp v5.13
Sal R. is offline   Reply With Quote
Old 11-13-2007, 07:11 PM   #133
UPDATE:
Well I've etched the PCB, drilled holes and started to populate the board when I realized, I didn't mirror the image before I printed it!!!!! ARHHHHHGGG!!! Crap, oh well have to start again!
Old 11-13-2007, 07:19 PM   #134
inh
uh... wouldnt it work the same anyways?
Old 11-14-2007, 12:37 AM   #135
_Dejan_'s Avatar
yes it work but he must put all elements on other side (on cooper side)...
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 93 08-11-2008 09:40 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 03:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 03:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 10:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 09:52 AM
