Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 10-30-2007, 09:52 PM   #1
OUSilver05 is an unknown quantity at this point
iR Repeater Project
Has anyone attempted to build something like this
http://www.bcae1.com/circuits.htm
It looks pretty simple, by my soldering skills are terrible. I have trouble looking at this diagram and figureing out where the power and ground go to, both look like they are on the fuse, which doesn't make sense to me. Does anyone have a finished picture of one, or a similar design? Would anyone be willing to make one for me for a small fee + parts? Thanks
Hardware: [-------- ]30%
Software: [----- ]20%
Install:[------- ]70%
2005 Subaru WRX - New 1.83 GHz Mac Mini - OSX/parallels is my front end - K301 InDash monitor
OUSilver05 is offline   Reply With Quote
Old 10-31-2007, 03:31 AM   #2
pbarrette is an unknown quantity at this point
Hi OUSilver,
The circuit is fairly simple. D1 is used only for reverse polarity protection. Remove it, as well as the black connection from D1->Fuse and D1->R1. So you are left with +12V->Fuse->R1. The rest of the black is ground. Just don't hook up the power supply backwards.
Actually, given the very low current draw of all components used, even the fuse is probably overkill. It's obvious that he's designed the circuit to be very robust under adverse conditions (read: idiot-proof), but the diode and fuse are basically overkill.
In fact, even R1 is overkill, assuming you have a clean 12v source. Besides, 1ohm 1/4Watt resistors aren't exactly common. Anyway, that's what C2 is there for: Noise filtering.
pb
pbarrette is offline   Reply With Quote
FS: Lilliput 8" LCD w/ 2 Project Housings migel628 Classified Archive 18 09-14-2005 07:40 PM
The Vectra CarPC / CarPuter Project v2 ccsnet Show off your project 28 08-29-2005 06:46 PM
IRMAN v. Cheapo USB IR Receiver....differences? hd54321 Input Devices 9 09-14-2004 02:44 PM
connecting IR receiver to EPIA mobo header chiefsalami Input Devices 7 09-02-2004 08:16 PM
RLion Project Webpage Reactor General MP3Car Discussion 0 02-18-2004 06:43 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
