Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 11-06-2007, 06:36 AM   #1
Simple on-off (10 seconds)-on circuit
Hi all, I have a 7" Tview monitor and as some of you know these things dont' like the cold weather. Pretty much what I have to do to get it to turn on in the cold is: 1)start my car (12v on to the LCD) 2)turn off an inline toggle switch to the LCD (cutting off 12v to the LCD) 3)wait 10 seconds 4)turn on toggle switch (re-supplying 12v to the LCD) I'm not talking about a pulse here, but the full 12v constant needed to be supplied to the LCD.
I'm looking for a simple relay/capicitor circuit to do this automatically since my toggle switch for the LCD is in the glove box. Any suggestions on this? Didn't really find anything on 12volt.com.
juve021 is offline   Reply With Quote
Old 11-07-2007, 07:32 AM   #2
Anyone have any guidance on this? Or is there a really simple solution to this and I'm missing something?
Old 11-07-2007, 09:51 AM   #3
Well, He asked for it.
WebDog's Avatar
What power supply do you have?
I had that same screen and the M1-atx and using the built in amp on connected to this worked great in the winter, You don't need to cut the screen power but you need to flip the power switch.
This one from the12volt dot com.
Switch = of course your car ACC/IGN 12V switch signal.
fulse 12+ (78) and momentary 12+ out (30) should be connect to 2 pins of the power button.
2005 VW GTI MKIV - SOLD
WebDog is offline   Reply With Quote
Old 11-07-2007, 10:09 AM   #4
thanks webdog...
I have the opus 250.
I don't know if your circuit would actually solve my problem though. I just physically press the power button on the screen to turn it on but even in the cold weather, after the 12v is hot to the screen, after I press the power button on the screen the green light comes on for 2 seconds then shuts off. If however, I cut all power to the screen (via the above mentioned toggle switch) and reapply power and then try to turn the screen on again, it works!
So I'm just looking for something to simulate the on-off-on of a toggle switch
Old 11-07-2007, 01:26 PM   #5
WebDog's Avatar
You can put that in so it cuts the power by wiring it to 87a, so it would then cut the power to your screen for about 1 second.
Old 11-07-2007, 01:40 PM   #6
Please explain...
Tank Circuit For Sale? mattdisaster Power Supplies 1 03-14-2007 07:07 PM
Question about the Diodes used in Ricky's battery based tank circuit nobb Power Supplies 4 08-15-2006 08:20 PM
delay circuit jshrieve Power Supplies 19 04-18-2002 10:38 AM
Timer circuit? Shutdown? dudah85 General Hardware Discussion 9 07-09-2001 07:22 PM
A simple delayed power-off circuit Oms General Hardware Discussion 3 10-27-2000 06:51 AM
