Quote: Originally Posted by
DEM_968
Hello Fmode,
Thanks for the response, could this power be also injected via the coax (P3) as it would be easier from the tuner end?
Just not sure of the circuit to prevent this power from also reaching the passive tuner.
How does the Terratec Cinergy turn on Diversity then, is this a problem?
Regards,
DEM_968
1. Open the Cinergy and look if there is a condensator behind the antennasocket - then its sure to power up the wire at P3 ...
2. only with Terratec's HomeCinema...
Can you switch on Diversity in HomeCinema and then leave HomeCinema - now use a BDA Viewer like DVBViewer or ProgDVB (free) and connect to one of the Cinergy BDA devices ?
May be this enables Diversity "for ever" (and for BDA) ... You can check this by removeing one antenna and picture should stay okay...
Thats what I never tested !
