01-14-2008, 10:38 PM
#1
Help building a wiring harness adapter to use 98 hazard switch in 01 Accord
I've got a 2001 Accord. I paid $250 to have a local car stereo shop modify a spare dash insert so that my LCD touchscreen would look great. After they started the work I realized that the dash insert was from a 1998 or 1999 Accord.
Here's a side-by-side comparison of the two model years:
Fortunately everything works fine - heater controls, clock, physical mounting, etc. Except: the hazard switch is wired differently.
After extensive tracing I've pretty much determined the differences in the connector mappings between the two and believe that if I could just swap the wiring leads that everything will work and look very clean.
However, I don't want to hack up the factory wiring. All along I've wanted to maintain the ability to easily switch from having a carputer back to a factory setup. So, I thought I could build an adapter harness.
Here's some more pics:
The top left pic shows the clock/hazard switch module coming out of the dash. The bottom right pic shows the wiring harness connector from both angles as comes from the dash. The top right pic shows the two switches side by side. The 01 switch is on the left and the 98 is on the right. The bottom right shows the connector on the back of each switch.
I need another wired harness connector like the male connector coming out of the dash. I may be able to find this at a scrap yard or other source as it would be the same as the stock connector. I'd also need a female connector like the one on the back of the hazard switch. I'd fashion a cable that crossed the pins so I could plug the female end into the stock connector coming out of the dash and the male end into the 98 hazard switch. If I want to return my dash to stock (no carputer and touchscreen) I simply disconnect the adapter harness and plug the original switch in.
Is this a good approach? Where can I find the parts? Anything else I should know or other comments?
01-15-2008, 11:51 AM
#2
MySQL Error
Why not just swap the hazard switch?
Or if you have the wiring diagram for both model, you can re arrange the pin at the connector and label the wires (for future ref) if you need to go back.
01-15-2008, 05:35 PM
#3
I forgot to mention that the switches are different sizes and shapes. They're close, but not close enough. It's not really feasible to switch the new switch into the older housing.
Now you're on to something. I suppose I could just rearrange the pins at the connector. What kind of tools do I need to do that? I've done some similar things with PC connectors a long time ago, but not automotive connectors.
01-16-2008, 03:55 PM
#4
^bump^ ... if anyone has any thoughts at all please post here. I'm getting desperate!  Thanks.
01-16-2008, 04:26 PM
#5
Have you tried looking through service manual (or related) literature to try to get a part number for the male plug on the harness, and then searching through connector re-sellers for whatever part that may be, looking of course for a female counterpart? It's a long shot, it's hard to do, I've done something very similar for a chevrolet plug, and it took an awfull lot of searching through the internet for a factory connector. ANd even then, they guy that I got it from had to (just for me) add it to his stock.
Also there is a thread in the forum on how to make your own molded plug, it was for a male, but maybe you can do a female in a similar fashion.
Search around for it if you want, when I get more time I will try and find it myself and post the link.
Later this evening I can try to help you find the male's pn from the OE Manufacturer and see if some of the contacts I've made in that industry can get the other half of the pair.
I'm not saying I can find it though, and even if I do, You may need to buy 50-100 of them
01-16-2008, 04:44 PM
#6
Laptop, Tablets, UMPC Moderator
well, to tell you the truth, what I would do is solder to the terminals at the new switch, then solder to the wires from the car. done deal. if you want to get fancy, solder to the new swtch, butcher the old switch & use the rear of it only & solder to that, then it will still plug in to the factory harness with no splicing...
you could also solder it all up & then use a different suitable disconnect plug for sevicing it too, I think gutting the old switch & using the back of that would be the approach I would take.
this is all asuming you can't just go to a junkyard & cut out the plug you really need, which is probably the best option.
getting that plug from the dealer probably won't hapen without buying a whole dash harness...
01-16-2008, 06:17 PM
#7
I think the problem is that the he wants to make something like an aftermarket radio adapter, something to plug in to the existing harness male connector, and then to the new switch. while keeping both parts prestine. Getting another hazard switch and that conmnector (with about a foot of harness wires still attached), hacking off the back end, and soldering the wires in, is a perfectly good way to go. Then if you wanted to make it look pretty, mold from the back of the hacked-off female, towards the wires about half of an inch to cover the solder job.
I know a few places where some plugs can be obtained from re-sellers that obtain them from the suppliers to the auto manufacturers. But the market is small and the selection is indeed limited.
Its probably overkill, IMHO. There's nothing wrong with a little splice and solder. Although  , I've done it.
01-16-2008, 06:41 PM
#8
well if he really wants pristine then he can cast his own plug  , but it's an 01 accord not an 08 rolls  , the only thing that would wind up butchered with my approach would be the 2 switches themselves, I would then mold in the rest with epoxy to finish it off & seal the wiring... it definitely isn't butchered to me that way, and it's done an hour after you thought about it.
when doing custom fabrication, one thing I've learned is, sometimes if you try to do everything too "correct" you may wind up never getting it done, I've seen guys get so anal that they build molds & cast brackets to not have to cut a piece of hidden plastic inside a dash. yeah, so 3 years later he's still working on an install that never got really installed. I've been there too, taking years for an install. sometimes the best way to do it is to just do it. this is trivial & not butchering anything more than 2 easily replaceable switches.
do it, done
01-16-2008, 06:53 PM
#9
That's probably why my 8" is still not in my altima bezel  . Good advice, I'm sure.
01-16-2008, 07:00 PM
#10
NO  , that's different, that's up front & center, shoot for flawless there & hopefully you'll wind up with really nice. this is different, it's unseen & would never take anything away from even a mint install. this ain't butchering at all, it's modifying
01-17-2008, 01:20 AM
#11
Here's the two switches with their guts hanging out:
The original switch is the one on the top.
The more I look at this the more I want to test it to be sure that my rewiring will work. Maybe I could use some wires with spade connectors - male spades to plug in to the factory connector and female spades to go on the new switch. Wonder if I could get the right kind of connectors at Radio Shack?
01-20-2008, 04:04 PM
#12
I dont know, I would just go to a junkyard, tell them that you want the switch for the 98-99 with a pigtail of wire (about 4 inches of wire) and use some taps to connect it up if its a big deal.
01-23-2008, 02:55 PM
#13
OK, made it to a junkyard today and cut out the pigtail. The next step is to test the wiring and make sure it works.
01-23-2008, 11:36 PM
#14
MySQL Error
I Just try it on the 2k Accord. By using a very small flat head screw driver jewelry or eyeglasses type(I used eyeglasses), I was able to pull 1 wire out of the socket/connector. Just pry the plastic clip and pull the wire.
01-28-2008, 12:33 AM
#15
Success!
I got an extra pigtail connector at the junkyard the other day. To test it I just stripped the wires, twisted them and stuck them into the factory connector in the appropriate holes. Everything worked great.
Here's how I wired them in case anyone needs the details. I numbered the connectors 1 - 9. Refer to the picture of the two connectors in the first post (bottom right picture). Connector number 1 is the bottom left, 2 is directly above it and so on with 4 being the top left. Then they start again from the bottom right with 5 6 7 together and 8 and 9 at the top.
2001 connector --> 1998 connector
1 --> 9
2 --> 5
3 --> 8
4 --> 1
5 --> 6
6 --> 7
7 --> 2
8 --> 4 (not used)
9 --> 3
| Thread Tools |
| Display Modes |
Linear Mode
