The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Thread Tools Display Modes
Old 03-13-2008, 04:34 AM   #31
rijk's CarPC Specs
Vehicle: 1994 volvo 440
My Photos: (0)
Quote: Originally Posted by HiJackZX1 View Post
you put it in the engine compartment, WOW that takes balls..... i would be so scared of the elements.
Only the cold is a problem rain isn't a problem, there would be water inside the car, before it would hit any part of the cpc. The fan of the car gifs planty of airflow, so cooling is plenty. And its very quite in this way.
Cold weather mobo list: Copy the list and add your board
http://www.mp3car.com/vbulletin/gene...ml#post1182447
my hidden screen http://www.youtube.com/watch?v=PrBeybwM_Is
rijk is offline   Reply With Quote
Sponsored Links
Old 03-13-2008, 06:15 AM   #32
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Quote: Originally Posted by RedGTiVR6 View Post
We've since cleaned it up a good bit too! Since I'm not using that sound card any more I got rid of all of the RCAs and since I'm no longer using a case (ran too hot), we got rid of some of that stuff too.
Glad it inspired someone!
Is that your competion car?
I thought you were using a PCI X-meridian sound card?
Did you get rid of it?
If yes, are you using the onboard sound? I don't see any cards on your board.
Is the scroll fan loud? I've been looking for a quiet fan for the computer myself as most of the small fans I've tried spin too fast (and thus, noisy) to move a suffecient amount of air for cooling.
Hmmm, maybe I'll check your worklog........
Cheers
Just curious.
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 03-13-2008, 08:11 AM   #33
_
RedGTiVR6's CarPC Specs
RedGTiVR6's Avatar
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
Nope - it just wasn't going to happen at that time so I pulled it out.
Nope - still planning on using it - be it in the house or otherwise.
Onboard optic.
Quote:
Is the scroll fan loud? I've been looking for a quiet fan for the computer myself as most of the small fans I've tried spin too fast (and thus, noisy) to move a sufficient amount of air for cooling.
Very loud...that's why it's turned off for critical listening. While driving though, you can't pick it out, which is fine by me.
For me to make the switch over to all tuning done by the PC in the car I would have to make some MAJOR changes. Having the entire sub-dash repainted being one of them. We sanded down the lower portion of the GTi dash (if you have been in a VW of this model you would immediately see why) and had it repainted in a flat black. The painter told us that if we ever needed to have a piece repainted, he would need to do the whole thing again to make sure the matte finish were uniform across all pieces.
Since the Alpine controller sits up there, it would have to come out, I'd have to probably buy a new center console and start a new. In which case I would move the CD drive to be above the screen and I'd see about putting an 8" wide screen vertically or even a 10" wide screen vertically in that spot and moving the AC controls down to where the alpine is currently.
Then there's the down time and the time spent retuning. It's going to happen, but since we were starting to consider buying a house, I couldn't justify the money we would have to spend to make the switch and the time down from shows.
Now we're putting a PC in the truck and I should be able to test the tuning that way to know EXACTLY how I want to do it in the car.
Jan Bennett
Centrafuse Support
RedGTiVR6 is offline   Reply With Quote
Old 03-13-2008, 08:51 AM   #34
rijk's CarPC Specs
My Photos: (0)
Maybe you can find one here: http://www.pcsilent.nl/en/Fans.2/25_40mm.34/
In the new position i use a 12 cm fan for the case (low noise 13 dB) and the EKL Xtrude mobile 479 for the processor
http://www.pcsilent.nl/en/CPU_cooler...9256dc2ccfbde2
Is a lot quieter than the Coolermaster i had (the same as on the picture of the mobo of RedGTiVR6)
No pictures of the new position, i always keep the new things hidden until after a meet (and thats april 20)
Old 03-13-2008, 08:55 AM   #35
greatwhite's Avatar
My Photos: (1)
Nah, I've got a toasted laptop that I'll be trying the centrifugal fans out of it. Doesn't matter how many mini fans I try, they're all too noisy in the trunk. The laptop fan might do the trick though....
Leonardo Da Vinci
Old 03-15-2008, 07:12 PM   #36
My Photos: (0)
I put mine where the passenger airbag should be.Easy to work on and get to.
Jarrod
jayrod7387 is offline   Reply With Quote
Old 03-16-2008, 01:13 AM   #37
My Photos: (0)
Behind interior panels (old install):
That just put my setup to shame. I'm going to rip it out over the long weekend and aim for smething like this. Back to the topic though, i put mine in the trunk. Plenty of space to work with, and i don't have much use for the trunk. One more benifit is the summer heat doesn't cause problems there.
Punky is offline   Reply With Quote
Old 03-16-2008, 04:24 AM   #38
Beezer's CarPC Specs
Beezer's Avatar
My Photos: (0)
Inside the (broken) factory autochanger casing.
Beezer is offline   Reply With Quote
Old 03-17-2008, 06:12 AM   #39
americasfuture2's CarPC Specs
americasfuture2's Avatar
Vehicle: 2008 Chevy Aveo
My Photos: (0)
^------ now thats a good use of something broken and in a stock location. how well does it stay cool?
Gathering parts----99% (I'll always want something else, its never 100%)
Using and programming in RR 3.14% (I need tons of help on this one!)
First Actual 98 Blazer LT Install
08 Aveo5 SV and 87 Fiero GT needing carputers
americasfuture2 is offline   Reply With Quote
Old 03-17-2008, 07:20 AM   #40
Beezer's Avatar
My Photos: (0)
It's been there for over a year & works fine. No problems with overheating even during summer.
Sponsored Links
Old 03-18-2008, 09:25 AM   #41
My Photos: (0)
In the trunk. I made a case out of a screw and bolt drawer set from Walmart. Barely big enough for the motherboard and PCI cards and allowed me to configure it the way I felt was best to maximize airflow.
SuperJ is offline   Reply With Quote
Old 03-18-2008, 07:27 PM   #42
My Photos: (0)
For you glove box guys....
Does the fan on the CPU (if you have one) keep it cool enough or do you use other fans or create vents to allow better cooling?
still_antipat is offline   Reply With Quote
Old 03-18-2008, 09:43 PM   #43
Vehicle: 2005 Scion tC
My Photos: (0)
...in the trunk - next to the spare tire.
www.QRXX.com
zzzBrett is offline   Reply With Quote
Old 03-18-2008, 10:50 PM   #44
IceMage's Avatar
Vehicle: 2006.5 / Scion / xB
My Photos: (0)
I put my caputer under the passenger seat. There's enought space for a mATX case and the A/C vent down there keeps the system cool in the Houston heat and humidity.
IceMage is offline   Reply With Quote
Old 03-26-2008, 11:01 AM   #45
Vehicle: 1999 Linconl Navigator
My Photos: (0)
I keep mine in the center console in the back seat.
Since then, I've added 2 fans and a lock. I'll prob update the pics later
jdiazj1 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
E46 BMW guys, any thoughts? GeddyT Newbie 25 03-09-2007 09:08 AM
I'm torn. New hybrid truck, very little space to put the computer... J187 Fabrication 10 02-19-2007 09:58 AM
Wants to Put a Computer in My Rav4 wengkun Newbie 1 10-16-2006 06:58 AM
What kind of computer to pick pulz Newbie 5 02-02-2006 04:08 PM
Troubleshooters! Computer turns off randomly and wont turn on, need help phatbimmer General MP3Car Discussion 4 06-05-2005 05:09 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
