Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 04-03-2008, 07:06 PM   #1
galvitron's Avatar
30 Second Off-Delay timer?
Hello all,
I've searched around but couldn't find an appropriate device.
I need an off-delay timer (around 30 seconds). I am not too good with soldering so I want an off-the-shelf circuit or module that will simply delay off for 30 seconds. When the it turns ON there should be no delay, but only when turning off. This will be wired into the ignition line so it would need to be 12V.
Any ideas??
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
galvitron is offline   Reply With Quote
Old 04-03-2008, 07:12 PM   #2
Quote: Originally Posted by galvitron View Post
Hello all,
Any ideas??
An idea ..
It's not an off-the-shelf answer, but look around for wiring diagrams on the "Retained Accessory Control" ciruits for some newer cars. This is a curcuit that keeps the accessories on, even though you have turned off the car. Then, they shut off accessories once the door (or some other trigger) is opened.
I have this on my 07 Grand Cherokee, but don't have the details on how its wired. I know i've seen it online somewhere.
NotYou is offline   Reply With Quote
Old 04-03-2008, 07:14 PM   #3
galvitron's Avatar
I appreciate your feedback but I will need the shut-off controlled by a timer and not another trigger, like the door opening.
I did find this:
http://www.astron.nl/~smirnov/poweroff.html
But I have no idea how to calculate the right components needed to get 30 seconds. If anyone has the ability to construct this I would be willing to pay for it.
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 04-04-2008, 09:27 AM   #4
MGD
MGD's Avatar
This circuit will work just fine. Istead of the 5 MOhm resistor you can use a 1MOhm TrimPot so you can adjust the time from 0 to 1 min.
MGD is offline   Reply With Quote
Old 04-04-2008, 02:23 PM   #5
galvitron's Avatar
Thanks MGD. Can you or anyone else recommend a place to buy this stuff? I have never bought these electronic components before...
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 04-04-2008, 04:27 PM   #6
I have a preference for ordering items from Mouser, and they have had a 100% success ratio with the several orders I've made (and one order had over 1000 individual items!). There's also digikey, though I have no experience with them. Be prepared to spend some time in their online catalogue finding the exact part you want, though, unless you have part numbers in advance. And be sure to have a PDF viewer installed to look at the linked data sheets =).
Locally, there's always RadioShack and (if you have one) Fry's. They will cost more then online vendors, and will a more limited selection then Mouser/Digikey -- but if they have everything you want, it might be easier in the longrun.
Old 04-04-2008, 05:28 PM   #7
Injector's Avatar
how about something like this is called a DEI 528t timer
http://cgi.ebay.com/DEI-528T-DEI528T...QQcmdZViewItem
Scion CarPC
Injector is offline   Reply With Quote
Old 04-04-2008, 06:22 PM   #8
galvitron's Avatar
How can I make that on off-delay timer? It looks like it starts the timer when trigger is started, not when trigger is lost...
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 04-04-2008, 10:58 PM   #9
Injector's Avatar
this might make it easier
Scion CarPC
Old 04-04-2008, 11:09 PM   #10
Injector's Avatar
or this will work too, when acc is on the relay will close and nothing will happen because 87 is not connected to anything, but when you shutoff the key the relay will open and 87a will receive negative which it will send to the 528t and start the timer.
Scion CarPC
Old 04-06-2008, 03:49 AM   #11
galvitron's Avatar
I tried to build the circuit I posted earlier and failed miserably...
I think I can manage wiring a relay to that timer. I will pick one up.
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 04-07-2008, 09:18 PM   #12
go online and find some time delay relay
easy and flexible
magnecraft.com is a manufacturer of some of those
EPIA TC 1G 256MB 60GB Linux,WindowMaker, Roadnav, Xine, XMMS, iGuidance3
Lilliput 8", Pharos i360, WUSB11v2.6 WiFi
dupa2 is offline   Reply With Quote
Old 04-07-2008, 10:31 PM   #13
we use these in some of our burg alarm or delay egress installs
http://www.altronix.com/index.php?pid=2&model_num=6030
rmanning201 is offline   Reply With Quote
Old 04-08-2008, 01:07 AM   #14
galvitron's Avatar
Those both look like On-delay timers...
I ended up ordering this one:
http://www.anderson-bolds.com/Mercha...tegory_Code=ST
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 04-08-2008, 07:24 AM   #15
Injector's Avatar
in reality it really doesn't matter whether it's an delay on or delay off, because with a SPDT (5 prong) relay you can invert it from delay on or delay off just by playing with the common open and common closed positions.
Scion CarPC
GPS Power On Delay sevin7 GPS 4 02-20-2008 09:11 AM
30 Min Off Delay, M2-ATX? Simon123 Power Supplies 23 04-02-2007 07:44 PM
555 Timer Problem.. Need it To Trigger when key removed fire Power Supplies 19 07-27-2006 04:44 AM
Speaker Popping Noise (delay circuit options?), Line Drivers to boost volume which 1? SuprchargdMazda General Hardware Discussion 9 05-26-2006 08:57 PM
