Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
View Poll Results: What is your skill level with microcontrollers?
I'm at least fairly skilled with microcontrollers. 29 60.42%
I've used microcontrollers just a little, but I wouldn't know how to do much with them. 4 8.33%
Never used one, but I have decent electronics and programming skills and would like to learn. 11 22.92%
It sounds too complicated, or I'm not interested. 2 4.17%
I don't understand what a microcontroller does. 2 4.17%
Voters: 48. You may not vote on this poll
Old 05-31-2008, 02:20 AM   #1
FordNoMore's Avatar
Question How much do you know about microcontrollers?
Ever since learning to use microcontrollers (PIC's in my case), I feel like a whole world of possibilities has opened up for electronics projects. I'm just curious if many people on this site know much about them or are interested in learning.
A microcontroller (such as a PIC) is basically a simple computer on a single chip. They cost maybe $5 each and can do all sorts of things. When you program them, you have direct access to input and output pins, so you can easily control relays, motors, or LED's, read switches or encoders, control or communicate with other electronics, etc.
It does take intermediate skill at computer programming to use them, and some basic electronics design skills to get much out of them. Also, even though they're cheap, they do require a programmer which is generally a few hundred bucks to buy.
*EDIT: Okay, I've been corrected. You can get programmers much cheaper than that. See replies below.*
Just wondering what the general skill level and interest is on this forum.
FordNoMore is offline   Reply With Quote
Advertisement Sponsored links
Old 05-31-2008, 02:25 AM   #2
Raw Wave
Rob Withey's Avatar
Know about them, have used them many times and will probably use them again.
The same is probably true for many people on this forum, you only have to see some of the projects here to realise that.
Programmers are not a few hundred bucks, they are far cheaper.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 05-31-2008, 02:29 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
We got a programmer for like $20 + shipping or something like that, and you can build one yourself if you are uber-geeky for a dollar or so in parts.
Old 05-31-2008, 02:31 AM   #4
eric_barcus's Avatar
never used, its a world id love to get into considering im a project aholic where should i start?
eric_barcus is offline   Reply With Quote
Old 05-31-2008, 02:32 AM   #5
FordNoMore's Avatar
What cheaper programmers would you recommend? I (from work, fortunately) got a Microchip Development Kit for I think $300. It's a really nice setup, with a USB in-circuit debugger and a demo board... but on my own dime I would have opted for something cheaper.
Old 05-31-2008, 02:32 AM   #6
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
Just finished doing a course at colledge for microcontrollers and c++ programming.
Infact I am writing a robot arm control program for my final assignment
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 05-31-2008, 02:49 AM   #7
FordNoMore's Avatar
This is a great reference for PIC Microcontrollers that starts from basics and is perfect for a beginner. I'm amazed that it's available online for free:
www.mikroe.com/en/books/picbook/picbook.htm
Old 05-31-2008, 05:07 AM   #8
meddler's Avatar
great link. thanks.
Old 05-31-2008, 09:05 AM   #9
got it and bookmarked it
Old 05-31-2008, 10:53 AM   #10
Raw Wave
Have used them many times from small project to something very complicated.
There are better MCU out there but PICs is the best one to get started, they have plenty of variety, supports, infos, projects and they give away free samples
As for the programer get the one with ICSP + USB and the one that would integrate with MPLAB, its productive that way. There are many other software you can use but I like MPLAB so im biased
Learn assembly language and you will appreciate how an MCU work much better, and you will be able to get the most out of it. Use ASM if possible then C.
Chris31 is offline   Reply With Quote
Old 05-31-2008, 10:57 AM   #11
Raw Wave
Here is a link to the ICD2 programmer
http://www.mp3car.com/vbulletin/hard...cd2-clone.html
Probably outdated now though, but yeah if you want to build one its fairly easy.
Old 05-31-2008, 12:30 PM   #12
FordNoMore's Avatar
I totally agree - learning assembly language first is a good way to go, just to get a feel for what's actually happening on the chip. And then when you start pulling your hair out because assembly is a pain to actually program anything sizable in, transition to C.
Along the same lines, I feel lucky that I started programming computers in the DOS days, using timer interrupts, polling the mouse driver directly, writing direct to video memory, controlling the sound card using low level port access... It gave me a tremendous understanding of a computer's inner workings that I would have never gotten if I'd jumped straight into high-level Windows programming.
Old 05-31-2008, 07:05 PM   #13
meddler's Avatar
got any good links to learning assembly?
Old 05-31-2008, 08:32 PM   #14
FordNoMore's Avatar
To be honest, if you've got just a little programming background, the link I gave above does a really good job of introducing assembly language for the PIC. (And a PIC is a great way to learn assembly language because the processor is very simple.)
Old 05-31-2008, 10:19 PM   #15
meddler's Avatar
cool... I have already bookmarked that one.
Do you know how to create a poll? FordNoMore Newbie 4 05-31-2008 06:46 PM
is there a wall to poll for directory list paths? Sonicxtacy02 Road Runner 7 11-30-2007 08:36 PM
Poll for best frontend qubitt Software & Software Development 6 08-05-2005 04:15 PM
want to make opinion poll abiout carmp3 /multimedia systems felix99 General MP3Car Discussion 1 07-15-2002 05:45 PM
