Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 08-12-2008, 07:11 PM   #136
Griff1's Avatar
Nothing less will do now i've seen this cam
Quote: Originally Posted by _Dejan_ View Post
now we are looking for good&cheap IR USB camera solution. If someone have any idea please tell us...
I think this is the kinda thing we need = http://www.digital-car.co.uk/forum/s...reverse+camera
Its not got Ir but with reverse lighting on it doesn't need it apparently.
Looks very nice,it is tiny and waterproof and uses a ccd instead of the usual cmos sensor.
If we can find some then maybe a group buy is in order.
P4 2.8 HT, 1GB Ram, 200Gb 3.5 HD, M4-ATX,2 x Silabs USB, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RoadRunner, iGo8,Custom Freedom 2.1
Griff1 is offline   Reply With Quote
Old 08-12-2008, 07:26 PM   #137
quantum's Avatar
Dejan,
PM sent!
COMPLETE! - 2002 Cadillac DTS - Summer 2008
http://www.mp3car.com/vbulletin/show...-complete.html
quantum is offline   Reply With Quote
Old 08-12-2008, 10:26 PM   #138
quantum's Avatar
Found this on hackaday, looks pretty simple and cheap...
http://www.hoagieshouse.com/IR/
http://www.hoagieshouse.com/IR/Creative/Creative.html
Old 08-13-2008, 01:40 PM   #139
I wonder if it posible to put an additional CAN reciver on the board, this would be great
I have the remote version from the parking sensors, but the unit is not working
Did someone know a way to messure the unit ?
cu
naruto is offline   Reply With Quote
Old 08-17-2008, 03:23 PM   #140
_Dejan_'s Avatar
USB PDC - Parking distance system:
one quick movie how work this USB PDC:
USB PDC
You need to upgrade your Flash Player
_Dejan_ is offline   Reply With Quote
Old 08-17-2008, 03:33 PM   #141
SWEET!!! looks the dogs!!! how does the front n rear sensor bits work n is the ready to get complete yet?
cheers
Baz
Bazza_84 is offline   Reply With Quote
Old 08-17-2008, 05:52 PM   #142
Looks good Dejan, see you got the 2 PDC bit working.
fridgemagnet is offline   Reply With Quote
Old 08-17-2008, 05:55 PM   #143
_Dejan_'s Avatar
For now work only 1 PDC kit. We are only prepare plugin for use with two PDC kits. But I think we must get PIC programed wit diferent serial or PID number... Will be Robby say how we will do this...
Old 08-17-2008, 06:30 PM   #144
Confusion Master
Enforcer's Avatar
I suspect the issue may not be whether Robby can change the serial or PID of the PDC kit, but that the xmitters for both kits will have duplicate IDs. so the receivers will not be able to distinguish between the two kits.
(Of course I may be wrong and the kits all have a unique frequency amd/or ID)
Anyone with two kits able to try this ?
Enforcer is offline   Reply With Quote
Old 08-18-2008, 12:57 AM   #145
_Dejan_'s Avatar
I think Wireless connection is not posible but If we connect it by wire then we don't have this problem and is problem only PIC(I think)...
P.S. I have at home two builded kits and I will try in next days
Old 08-18-2008, 07:38 AM   #146
Failing that, you could have one wired and one wireless.
That might even be better as the control units will be at opposite ends of the car anyway.
Old 08-18-2008, 07:46 AM   #147
_Dejan_'s Avatar
Yes this is second option(more useable)...
Old 08-18-2008, 08:31 AM   #148
Confusion Master
Enforcer's Avatar
Good point, two wired directly would get around that.
Failing that, you could have one wired and one .
That still might not work.
Even when connected by wire the second one will still send it's wireless signal which may confuse with the other one.
Old 08-18-2008, 08:36 AM   #149
_Dejan_'s Avatar
Yes you are right
Old 08-18-2008, 11:54 AM   #150
Good point, would have to stop power getting to the transmitter.
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 101 11-11-2008 08:33 PM
USB Syncroized 5V@10A power supply POL. Now Taking Orders!!! Beehphy User Innovations 102 09-17-2008 06:07 PM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
