Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 10-05-2009, 10:21 AM   #316
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
Quote: Originally Posted by HoSS View Post
Could someone please clarify how front & rear PDC is done.
- Do i need 2x 4 sensor kits, or 1x 8 sensor?
- Do i need 2x the USB-PDC boards, or one?
TIA HoSS
You are right.
You need:
2x USB PDC kit with diferent version of PIC
2x 4sensor kits one you must have connected by wire
Im say how to do this min cca. 2-3x...
_Dejan_ is offline   Reply With Quote
Old 10-05-2009, 10:46 AM   #317
Markil is an unknown quantity at this point
Quote: Originally Posted by _Dejan_ View Post
If you need "source code" for PIC you will not receive it
Hi Dejan,
I need a programmed PIC to mount on my board..
could be possible??
Markil is offline   Reply With Quote
Old 10-05-2009, 02:14 PM   #318
_Dejan_'s Avatar
Quote: Originally Posted by Markil View Post
Hi Dejan,
could be possible??
Sorry I can't provide you only PIC. Why? Because I have only 2 and Robby will not be back until december and then I can't sell my boards, which I have at home...
Best regards, _Dejan_
Old 10-05-2009, 03:11 PM   #319
Ok...............
I'll wait till Robby returns..
regards...
Old 10-05-2009, 04:09 PM   #320
f1racr is an unknown quantity at this point
My understanding is 2 x USB PDC boards (one has a slightly different PIC software). Each board runs 4 sensors.
** Edit ** Dejan beat me to it !
f1racr is offline   Reply With Quote
Old 10-05-2009, 04:34 PM   #321
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
To run back and front.
At least one has to be run wired.
You can not run both wirelessly as the sensors from both units will xmit on the same frequency with the same ID.
Enforcer is offline   Reply With Quote
Old 10-08-2009, 06:30 AM   #322
_Dejan_'s Avatar
Ok...............
regards...
Hi,
Do you need it for front or rear system? Which front end you will use? Centrafuse or RR?
I have avalible only V1.10 which is designet do use with front system but in Centrafuse can be used as rear, because you can select which device you will use for rear system and which for front. Im not shure if in RR is this possible... If you are interested send me PM...
Old 10-08-2009, 07:44 AM   #323
Hi,
PM sent! Thanks!!
Old 11-04-2009, 03:59 PM   #324
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Dejan... tell me you dont have a list of people waiting for december to roll around . I cant wait til ya have some back in stock!
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 11-18-2009, 05:25 PM   #325
boelle is an unknown quantity at this point
what happens if i connect one front and one back (each with the right pic inside) and power them up at the same time.. will the plugin show the graphic beam thing only at the back of the car or will it show at the front also? have some tried to install both modules and can provide some screenshots?
boelle is offline   Reply With Quote
Old Today, 05:52 PM   #326
Ottmar is an unknown quantity at this point
Hello!
Very interessting System like also USB-TPMS!
@_Dejan_:
On what date i can order the complete kit (incl. 3rd eye) again from you?
EDIT: PM Sent to _Dejan_!
thanks,
greetings,
Ottmar
Ottmar is offline   Reply With Quote
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
USB Syncroized 5V@8A power supply POL. Now Taking Orders!!! Beehphy User Innovations 110 06-23-2009 04:22 PM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
