07-23-2008, 08:28 AM
#106
Greek language added!
_______________________________________
Car installation 95% [ ■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
07-24-2008, 06:54 PM
#107
I may be misunderstanding, but how come there isn't a small little beeper on the PCB like this ? or at least the holes to be able to solder one on if you want it ?
07-25-2008, 06:45 AM
#108
I might be wrong but i think the idea is that the buzzer remains remote so you can locate it where you like even if your usb pcb is hidden or in the boot.
P4 2.8 HT, 1GB Ram, 200Gb 3.5 HD, M4-ATX,2 x Silabs USB, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RoadRunner, iGo8,Custom Freedom 2.1
07-25-2008, 06:51 AM
#109
Confusion Master
The BMW E36's have a gong under the drivers dash, which is designed to be used with a PDC, so 'we' can just run wires to this
There is a connection on Robbys board to run to a buzzer, bong or whatever sound device.
07-25-2008, 11:18 AM
#110
No need for a buzzer or gong. There is a Label on the screen which shows you the distance. Mine announces the distance in feet every sec. when you back up.
07-25-2008, 12:48 PM
#111
the buzzer or gong is meant for when you don't have your pc running, so you're sensors will work even then
Greetz
Dj NRG
07-25-2008, 05:14 PM
#112
Hi, guys
i have produced and mounted the circuit Robby, everything worked perfectly.
I mounted the buzzer circuit original parking system and works to perfection.
Thanks Robby
Reason: image change
07-27-2008, 07:59 PM
#113
Hi everyone.
I have a "no drill" or electromagnetic strip parking sensor.
Will this interface work with it?
Mine is a clone of the proxel unit ( http://www.proxel.com/).
Any input will be appreciated.
2005 S40 2.0D - Sport Body Kit
Ipod 100%
Carpc 95%
07-28-2008, 12:53 AM
#114
Quote: Originally Posted by mJrO
Hi everyone.
No. Because for LED and LCD PDC you need diferent PIC, so if board is compatible with this PDC Robby must write new code for this PDC...
07-28-2008, 04:09 AM
#115
Quote: Originally Posted by _Dejan_
hi,
Plugin for CF is in developing. Wolfgang develope it like Plugin for TPMS...
In 14 days I will have prepared completes for sale, builded together without PDC(board with all elements, programmed PIC and case)...
Hello,
Is there any news regarding Centrafuse plug in ?
Cheers
07-28-2008, 04:20 AM
#116
Quote: Originally Posted by AIR-V
Hello,
Cheers
Hi,
Wolfgang is on holidays. Today Im receive connectors and I will complete and send device to him and others guys who are order it... I think that when receive device, he will continue with developing plugin and complete it quick... Maybe he will need help with skin... I will ask him and write here...
Bye, _Dejan_
07-29-2008, 08:46 AM
#117
If there is someone interested to have board with PIC now are avalible...
LINK
07-30-2008, 08:04 AM
#118
Had a look through and couldn't see if anyone has mentioned this already but;
Will this board and software work with the 6 and 8 sensor versions?
07-30-2008, 10:16 AM
#119
No, because the two firmware were developed on the 4 sensors version.
Most probably, is possible to develope a new firmware able to work with the 6 and 8 sensor versions, but I would need one of these sensors to analyze the data.
07-30-2008, 10:27 AM
#120
I'm not sure whether it is cheaper to buy two 4 channel PDC versions or a single 8 channel version.
If 4 channel versions are turning out to be cheaper (possibly because of large volumes), how about a single PIC handling 2 PDC boards (Front and Rear). I'd imagine the modifications required could be minimal and the PIC will have ample I/O's and on-chip resources left for this additional 4 channels.
| Thread Tools |
| Display Modes |
Linear Mode
