Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
View Poll Results: Would You Use It
Yes 7 100.00%
No 0 0%
Voters: 7. You may not vote on this poll
Old 11-29-2008, 06:08 PM   #1
proph's Avatar
proph is on a distinguished road
Washboard: Remote PC Startup and Shutdown (w/ video)
I'm checking to see if there is any interest in a unit that will turn on your carputer from your alarm? The picture below if just a remote, and not part of the Washboard. You should be able to add the Washboard to a pre-existing alarm setup.
Here's how it works... Say I'm sitting on my couch, and I want to turn on my carputer for syncing, a file transfer, or just to install something. I press a button (or button sequence) on my alarm and it turns on my carputer. I do what I need to do on the puter, then hit another button on my alarm to turn it off. A couple local's here have seen me use, and have inquired about it... See the demo below:
Washboard
You need to upgrade your Flash Player
The unit is about 2"x2"x1" so its very small. I've built a prototype, and have made improvements to it. Is there any interest in a unit that did this?
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
proph is offline   Reply With Quote
Old 12-07-2008, 11:56 AM   #2
proph's Avatar
Updated w/ video...
Thanks for your input Rodney!
Setup:
Dynaudio 240GT
Zapco DSP6
ADS DAC
Old 12-07-2008, 12:34 PM   #3
b3tts32's Avatar
b3tts32 is on a distinguished road
My experience with the washboard
I’ve been using a prototype of the washboard for a little more than 30 days now and I can say that I’ve been more than impressed with it. It’s certainly done the job for me in many different instances in which I have had issues before.
The first issue being that I live on the 3rd floor of my apartment complex, so it makes things tough when it comes to working on the pc. I would have the hassle of pulling the pc out and bringing it upstairs to work on or leaving the key in and using vnc or remote desktop. Problem being that my keys are in my car and I’m on the 3rd floor! With the washboard I can turn on the pc from my apartment and take care of any work that needs to be done and turn it off.
The next issue that came up was the cold weather thing. My pc doesn’t want to play nicely unless it’s been running for about 15 minutes or so and warmed up. My car is a standard so that rules out remote start of the car in general. So again with the washboard I could just turn on the pc 20 mins or so before I was ready to leave for work in the morning .
The Last issue that I had always dealt with was my computer freezing for whatever reason and I would have to go to my hatch to reset it or kill the power. I never did get around to wiring a kill switch or anything like that to the front so this got to become a big problem. So now I have a function on my alarm remote that restarts the pc so this has been a lifesaver.
In conclusion, I can honestly say that the washboard has done everything I needed and more. For some it may just be the convenience of having it, but for me I believe it’s a necessity for my carpc to function the way that I’d like for it to. With the little hardware that’s required I’d recommend this for any and everyone really. As they would say on reading rainbow – “You don’t have to take my word for it”
b3tts32 is offline   Reply With Quote
Old 12-07-2008, 12:43 PM   #4
D3StRoY's Avatar
D3StRoY is an unknown quantity at this point
That looks great, really useful indeed, i would use it!
Great work !!
D3StRoY is offline   Reply With Quote
Old 12-09-2008, 08:25 PM   #5
proph's Avatar
If there's enough interest in the piece I'll build it out... I'm working on a timer for the unit as a failsafe.
Setup:
Dynaudio 240GT
Zapco DSP6
ADS DAC
Old 12-10-2008, 12:40 PM   #6
D3StRoY's Avatar
Well im interested, depends on how much this device (with controller?) will cost
But its very useful to send all my music etc to the car without the need to go outside and boot everything up !
Old 12-10-2008, 12:57 PM   #7
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
very interested as well depending on price
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 12-10-2008, 01:46 PM   #8
Maheriano will become famous soon enoughMaheriano will become famous soon enough
My car is a standard, I have remote start. Had it installed for 3 years now, works fine.
This unit looks pretty good, though why can't you just hook your alarm brain directly to the computer? Is it possible to hook an AUX output on the brain to the switched line in the car so that the motherboard receives the signal to turn on via the switched line like normal?
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 12-16-2008, 08:47 PM   #9
proph's Avatar
What's creating and holding the latch Maher?
I'll complete the work on this, and send out some pics probably late next week after the pcb's come in.
Once I've completed it I'll let everyone know the cost on it... probably around 50 shipped.
Setup:
Dynaudio 240GT
Zapco DSP6
ADS DAC
Old 12-17-2008, 01:07 AM   #10
fabworks is an unknown quantity at this point
it's a cool idea and thing to have, the only issue that I see is if you forget to turn the computer off after having it turn on with the remote. Your battery will be drained.
fabworks is offline   Reply With Quote
Old 12-17-2008, 08:05 AM   #11
b3tts32's Avatar
I think he's working on a timer that will turn off after 30 mins or an hour or so. Not sure the exact details but he did say he would try to get that worked in.
Old 12-17-2008, 10:39 AM   #12
WuNgUn's Avatar
WuNgUn is on a distinguished road
I don't understand...what is a washboard??
And watching that video, it looks like a very abrupt power off! Is it killing the power to the PC/Monitor, or initiating a shut down sequence?
I've done a remote on already with my Viper alarm, a relay and a diode...simple as ****...triggers the ACC on the OPUS for on AND off...
WuNgUn is offline   Reply With Quote
Old 12-17-2008, 06:54 PM   #13
Minoritydan is an unknown quantity at this point
slight change of topic here, but for those that have remote start on their vehicles, where do you get the signal from the remote start to turn on your PC?
I tested mine, and the remote start does not trigger my ACC/IGN wire on my radio harness, so I can't start my PC with remote start. What are you tapping into to turn on your carpc w/ remote start?
Minoritydan is offline   Reply With Quote
Old 06-09-2009, 09:49 AM   #14
bass29 is an unknown quantity at this point
Washboard info
Is there anymore info regarding this product and how to connect it ????
bass29 is offline   Reply With Quote
Old 07-21-2009, 01:06 AM   #15
AJoc is an unknown quantity at this point
Does anyone have one of these, because I really hate waiting for my computer to startup!?!
AJoc is offline   Reply With Quote
Testing waters; WoW account? simzo Classified Archive 7 04-06-2006 01:44 AM
Testing the waters: mini itx p4 mobo and cpu EsKALad Classified Archive 15 12-31-2005 10:46 PM
Testing the waters xs10x Classified Archive 4 09-02-2005 08:03 AM
testing waters...F/S xbox with 9 games im a nub Classified Archive 6 05-26-2005 11:23 PM
Testing Waters, taking offers. Full Carputer Setup! tiggs Classified Archive 19 05-20-2005 11:29 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
