Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 12-05-2008, 07:18 AM   #1
d_mc_a is an unknown quantity at this point
Arduino BT CarPC power controller
Hi,
I've been getting annoyed at my pc as it drains my car battery alot. I know there are plenty of alternatives but I just wanted to see if anyone has tried this or thinks its a crazy idea. I have an arduinos BT. The great thing about this device is that it can operate on a voltage as low as 1.2v. My idea is to install this in my car with the operating voltage at its lowest so that the range of the arduinos is reduced. I have a small program in the works for the arduinos(not tested yet) that will continually scan for bluetooth devices and trigger depending on the detection of my phone. The idea will be that this arduinos is always powered with a reduced bluetooth range around the car. When it detects the phone in range, It switches on the carpc on, when the phone leaves range, a timer begins that first, locks the carpc for up to 1 minute of no phone detection. If the phone remains out of range for a longer period (probably 5 minutes), the arduino will shutdown the carpc. When the phone comes into range again, It will switch on the carpc. I have been trying to work it our logically so that when I'm near the car, or walk past the car, it won't switch on and stay on.
I'm aware that their might be some security issues with my way of ding this but as the arduino only controls the PC and not the actual ignition, I don't really care about that.
Sorry about the long msg.
d_mc_a is offline   Reply With Quote
Old 12-05-2008, 07:02 PM   #2
Kevin94bird is an unknown quantity at this point
Will a startup/shutdown controller not work for you? you can set it to wait an amount of time once the car is off before it shuts down if ignition is not detected again.
Kevin94bird is offline   Reply With Quote
Old 12-06-2008, 09:19 PM   #3
84RegalRider's Avatar
84RegalRider is on a distinguished road
well since he is using an arduino, i think adding the delay is like two lines of code. haaha
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
84RegalRider is offline   Reply With Quote
Old 12-08-2008, 08:22 AM   #4
Yea, A simpler controller would work but I want to add the possibility of other bluetooth features later on. Triggering other events on the car from the phone, for example changing to a socket connection via bluetooth to the arduinos and some kind of interface on the iphone that can open the boot, or switch on lights without the pc having to be switched on. I have already bought a damaged logitech G15 keyboard off a friend and I'm going to remove the LCD from it and replace the stock clock LCD on my renault with it. I'm not sure how easy it is to integrate a G15 lcd with an arduinos, but I'd imagine someone has tried it. That should allow for some interesting features.
Old 03-18-2009, 10:20 PM   #5
rodweb is an unknown quantity at this point
I've been playing around with an Arduino as well this last week or so. They are very clever. To turn the Car PC on, all you need is to trigger a relay in the accessory line that turns on your PC power supply and maybe a sensor on the ignition line so if the engine is on, you don't kill the Car PC as there is no load on the battery.
Another alternative is to sense the battery voltage with one of the analog pins thorugh a voltage divider and if it falls below say 13 volts (eg. Alternator is not charging) allow the Arduino to shut down if the BT signal is lost.
To sense 12 volt voltage, feed the 12v input to a relay (maybe a solid state one) on the input side and switch 5 volts on the Arduino onto the input pin you are using.
I've started to put some stuff together from my car PC
These ar Solid state relays, 2 amps 3-50 volt DC. There are 4 input relays and 4 output relays on this board I will be using. There are two kinds of relays here. One lot handles a 12 volt input (which will be inputs to the Arduino), the other handles 5 volt input (which will be outputs to the Arduino)
I've also got some smaller ones that can switch at < 3 volts.
The LED's represent the buttons on my monitor and when reversing lights are sensed, the Arduino will press buttons to switch inputs. The press button switch represents the reversing light switch. I have put stuff about this on my worklog and the first cut code for the monitor is there.
I will also make the Arduino work as a temperature sensor for RR. I have tested this and it works!
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Review: M4-ATX 250 Watt Intelligent Power Supply Bugbyte The Review Palace 10 11-17-2009 10:32 AM
Use a UPS to power a CarPC R33vit Power Supplies 2 12-05-2007 02:15 AM
HOW TO: Getting your CarPC ready before installing it in your car. xraycat General Hardware Discussion 2 09-13-2007 01:53 PM
Power help for new laptop CarPC jwaters Laptops, Netbooks, Tablets, UMPCs, etc. 13 01-06-2007 02:15 PM
P 1280 AND an inverter to power my carpc, make sense? Will Albers General MP3Car Discussion 0 05-24-2005 12:50 PM
