Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 08-22-2009, 10:32 PM   #1
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
My $15 12v Automotive 7-port USB hub
With all the talk around here regarding automotive USB hubs and all that, I decided to take everyone's advice and build one. Here's how it came out:
As you can see, there are 7 ports and it clips right into the radio harness to grab power, ign, and ground. Tomorrow I'm going to hot glue it all so that it's a bit more sturdy and add some terminals so I can use the output from my IGN relay.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 08-22-2009, 10:38 PM   #2
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
good work. I look forward to some more info about this.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 08-22-2009, 10:58 PM   #3
Punky is on a distinguished road
Looks sweet!
curious why you chose to use the radio harness instead of just having +/-/ign, seems less flexible to me.
Punky is offline   Reply With Quote
Old 08-23-2009, 01:21 AM   #4
colin's Avatar
I made it for me. Its simplest for me to get an IGN line from the radio harness and tomorrow I'm going to put some terminals at the top so I can access the IGN line and send it out to my amps. That and all my USB devices are up front so it just works out best.
I basically just ran the IGN from the harness into a relay that switches the battery when the car is on. Then that goes out to terminals for later and also into a DC-DC regulator. That puts out 5v at 3A for the USB hub. Stuffed that in an old project box and bam all set
Blog
Code:
Old 08-24-2009, 02:58 AM   #5
don't mind me asking, what's in the box?
Old 08-24-2009, 02:45 PM   #6
colin's Avatar
Exactly what everyone said to use.
Inside the box is a relay, a DC-DC step-down converter, and the USB hub. A little soldering here and there and I have a high-power IGN circuit and a 12v USB hub with 7 ports
Blog
Code:
Old 08-25-2009, 01:06 AM   #7
rockyct is an unknown quantity at this point
Where did you get the step down converter? Also, I'm assuming the way you wired it (relay off the ign wire?), the hub isn't powered when the car is off.
rockyct is offline   Reply With Quote
Old 08-25-2009, 02:14 AM   #8
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
did you just do step down, or did you do buck-boost? Did you integrate a microcontroller for startup/shutdown delay or simple relay on/off with the car activation?
Have you taken the lifespan of the relay and the induction of the coils into effect on sensitive USB lines?
Old 08-25-2009, 12:27 PM   #9
Buck boost is definitely the way to go here, it'll give you a much wider voltage range and would make it more car suitable. I don't think he used a ucontroller from the sound of it, and plus its probably add unnecessary complication if he did.
personally, i always used the extra usb header ports on my motherboard (most have 4 to 6 + 4 USB header) because i just want to avoid usb hub altogether.
Old 08-27-2009, 12:13 PM   #10
colin's Avatar
Guys, this is seeming way too complex. It's a simple hub. I used a Step Down DC/DC converter. I believe it is based off a buck circuit. Input voltage ranges from 4 - 25v and the output can range from 1 - 10v or 1.22 - 6.70v depending on the precision. It has 3A maximum output at 5v. At a full 3A, the efficiency is 90% whereas at about 1A it's 93%.
Yes, I have considered the "sensitive USB lines" and they are fine. The relay is an old one I had lying around since I bought so many of them. They have a very long lifespan if powered properly.
Yes, the hub loses power when the car is shut off. Remember this was just for me and that's the features I would like since I've had so many problems with my car starting nicely. I was posting this to show that it CAN be done.
No, there is no microcontroller. Although I am proficient in microchips, I did not see any need to add such complexity to this otherwise simple use! You need a relay, a power converter, and a hub. Shutdown controllers are for the computer. If you want this thing to shut off when your PC shuts off, then use the 12v line on your molex connector as the IGN line for the circuit. It will turn on when your PC turns on, and turn off when your PC turns off, the whole time using power from the car.
Any more questions? I just wanted to show that it can easily be done for much less than the $85 that MP3Car wants for a similar product. If, like me, you don't need those extra crazy features, this will be perfect.
Blog
Code:
Old 08-27-2009, 07:42 PM   #11
Do you have a schematic for the DC step down circuit or a website where I can buy one?
Old 08-27-2009, 09:26 PM   #12
Hekim is an unknown quantity at this point
Cool. So when you turn off your ignition do you go into standby or hibernate on your PC?
Hekim is offline   Reply With Quote
Old 09-12-2009, 08:34 PM   #13
colin's Avatar
The power converters are on eBay as posted in another thread, no time to look. They're about $8 shipped, maybe less.
When I shut off my ignition, I hard-off. I don't care about the "possible" problems. If my car goes off, so does the computer. I do have a switch that will hold power but that is risky business. My bootup times are about 10 seconds, so turning on is not a problem for me.
Blog
Code:
Old 09-13-2009, 05:40 AM   #14
I think this was posted before: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT but it's about $15 shipped. Was this the one or is it a different one?
Old 09-13-2009, 12:21 PM   #15
colin's Avatar
That's the one, but it only came to about $8 shipped. To Canada.
Blog
Code:
12v USB Hub - $29.99 :-) kapone General Hardware Discussion 39 10-07-2009 12:51 PM
USB Hub Doesnt Work On Boot - Help we87 Input Devices 4 08-03-2008 12:12 AM
USB hub from touchscreen port? sama General Hardware Discussion 11 04-11-2006 07:23 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
usb hub with 12v psu etrik General Hardware Discussion 4 06-30-2001 02:06 AM
