01-07-2006, 03:10 AM
#31
Hi guys try this website out, has lots and lots of connectors.
Let me know what you guys think.
http://pinouts.ru/cgi-bin/list_conn.cgi
Cheers
Guruj
01-17-2006, 01:07 AM
#32
Vehicle: 2002 Thunderbird V8
Shutdown Controller "Keep ON" with auto Reset
This circuit will bypass the ignition switch signal in order to keep an M1-ATX on after the key is turned off. The push button and LED are mounted on the dash. To keep the PC on during a quick stop, I push the button before turning off the key. The LED lights up to indicate the Latched on state. The system will automatically reset to normal (unlatched) the next time the key is turned on. The circuit will also unlatch if the PC turns off for any reason (low battery, software shutdown, PC power switch, etc.) This circuit has been tested with M1-ATX, but should work for other SDC's with ignition control signal.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/STR
~Jimmy
01-20-2006, 10:45 PM
#33
Since the Mute line in a car may be already used, adding a Handsfree Kit or other device with a Mute line needed some "glue" logic.
Common Car Mute line function is active low, a 74HCT08 2-Input AND Gate is used so any low input will cause a low output to the radio. A 7805 5V regulator is used to power the logic gate. Pull up resistors are added to keep the input/output stable preventing any unwanted mute condition caused by drifting line levels. If more than 1 Mute line needs to be added, a 74HCT11 3-Input AND Gate can be used instead.
02-05-2006, 12:36 PM
#34
I'm looking for the pinout of a 2003 ford cd-6(indash 6-disc changer) 20 pin cd changer.I'm trying to get aux input out of it!Ive looked and looked and If anyone could help me it would be appreciated!
02-08-2006, 02:26 PM
#35
Vehicle: 1994/Honda/Accord
Regarding the carPC Turn On / Shutdown Controller i ve one questions?
1) What if i don't have COM port ? can i use USB or Parallel port?
HOnda Accord '94
02-27-2006, 02:17 PM
#36
Vehicle: Renault 19 (1992)
Simple car battery tester
Link: Simple car battery tester
04-01-2006, 04:15 AM
#37
Vehicle: 2002 Wrangler 4.0 / Audi 100 2.2
For anyone looking for any kind of connection description forward this link. Is the most complete and easy to understand Connector description (graphic & text) I have found.
http://www.hardwarebook.net/connector/
IN ENGLISH
04-01-2006, 07:24 AM
#38
Raw Wave
04-01-2006, 07:39 AM
#39
Raw Wave
PS2 Port Pinouts
04-03-2006, 05:43 AM
#40
Sorry, I've wrote the wrong link. The right link in English is:
I've allready corrected in my message.
Hope this link helps anyone seeking for any kind of connectors!!
05-22-2006, 06:05 AM
#41
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Vehicle: 2004 4Runner SR5 V8 4WD
Since it was brought up elsewhere, I figured I'd post it in here as well since this is an appropriate section.
If you need to drop 12vdc down to say 6vdc or 8vdc for external devices (hubs, tv tuners, etc), you can use the calculator -HERE- to figure the resistors needed to drop the voltage. It will even show you the circuit to build. This is a voltage divider circuit.
05-22-2006, 06:39 AM
#42
MySQL Error
Vehicle: 2002 Dodge Ram 1500 Quad Cab
Just a warning, dont try to use this circuit with high amperage items, unless you are prepared to get rid of some serious heat and buy some monster heatsinked resistors. Some of these USB hubs and such draw upwards of 2.5A which to put through a resistor is some serious wattage. In those cases you have to go with a switching power supply, or even a high amperage linear chip.
05-22-2006, 08:44 AM
#43
lol good point. I was only thinking of dropping the voltage, not really the overall outcome from doing so... I guess this is good for the low current apps, but not for the hubs, etc like you said. I think my hub's pull is ~1.75A.
06-18-2006, 01:42 AM
#44
Vehicle: 1999/Ford/Escort ZX2
hey JimmyFitz where do you get your parts from, the relays and things like that? and how hard is it to make that circuit to keep the power supply on when the car is off?
Corey
| Thread Tools |
| Display Modes |
Linear Mode
